My Zencart will not switch between Responsive blue and responsive classic template. It will switch to the old standard template. This happened after I also installed responsive blue template.
Thanks for your help.
Perhaps information at this link will help? Also are you using version 2.0 of the responsive (sheffield?) blue template?
https://www.zen-cart.com/showthread....79#post1306879
Yes I am using 2.0
Sheffield blue works fine, however I wish I could switch to the other responsive template. I could do a reinstall but not sure whether that will help.
Go through the actions of the thread previously posted to see if that resolves the issue(s).
