Results 1 to 10 of 11
    red flag Need help for fix MySQL to MySQLi Error on old moudles
    I am upgrading a ZC 1.5.1 to ZC 1.5.4
    The ZC 1.5.4 logs see some log like this
    PHP Warning: mysql_query(): Access denied for user 'user'@'localhost' (using password: NO) in /home/user/public_html/zc/admin/shipping_export1.php on line 1194
    PHP Warning: mysql_fetch_array() expects parameter 1 to be resource, boolean given in /home/user/public_html/zc/admin_xx/shipping_export1.php on line 1195
    PHP Warning: mysql_query(): Access denied for user 'user'@'localhost' (using password: NO) in /home/user/public_html/zc/admin/shipping_export1.php on line 1198
    PHP Warning: mysql_query(): A link to the server could not be established in /home/user/public_html/zc/admin/shipping_export1.php on line 1198
    Yes, yes it is a Export Shipping+Order Information
    but .... since some reason, I need change it to match my need, so above file named shipping_export1.php
    While I google some inform know that from ZC 1.5.3 starting move from MySQL to MySQLi
    And I also see the
    Zen Cart’s database abstraction layer
    https://www.zen-cart.com/wiki/index....ers_-_Database
    But ... not too understand how to fix my self coding
    Here are my coding that can work on ZC 1.5.1, but not the ZC 1.5.4
    where the shipping_export1.php on line 1194 is below "$yu"
                    $payment_term
    =$module->title;
    $payment_method=(strstr($module->code'paypal') ? 'PayPal' $module->code);
    $yu=mysql_query("SELECT * from required_definitions where payment_method = '".$payment_method."'  ");
    $req=mysql_fetch_array($yu);
                    if(
    $req['payment_method'] != $payment_method)
    mysql_query("INSERT into required_definitions (payment_method,class,class_name,definition) VALUES ('".$payment_method."','','','')");
    and after I am read the
    I had try change the line 1194 to
    $yu=$db->Execute("SELECT * from required_definitions where payment_method = '".$payment_method."'  ");
    then the logs not show error on line 1194 anymore, but ... I still see error on line 1195, 1198, no example for me as reference, I am lost of idea how to change it using $db->Execute way ..
    Any one can help me fix it? Thank you.
    Feb 2006
    Tampa Bay, Florida
    Default Re: Need help for fix MySQL to MySQLi Error on old moudles
                    $payment_term
    =$module->title;
    $req=$yu->fields['payment_method'];
                    if(
    $req != $payment_method)
    $db->Execute("INSERT into required_definitions (payment_method,class,class_name,definition) VALUES ('".$payment_method."','','','')");
    Dec 2009
    Amersfoort, The Netherlands
    Looks like the rest of the code may also need an overhaul, because the table names are also hard coded.
    Feb 2006
    Tampa Bay, Florida
    If it worked before, it means he's not using a prefix. I agree this is not best practice, but there you are.
    One thing @explorer1979 *should* be on the lookout for is missing sanitization of input values, which was common in older modules.
    design75,
    Hi, thank you of your suggestion, I write this since I using phpmyadmin most time..
    Directly using it SQL tab to write SQL, so if can work I will copy and paste on it.
    And like what I said before, this is my self need custom coding for my shop output some special CSV, not include on original "Export Shipping+Order Information" official ZC module.
    swguy,
    Thank you, your coding work for me.
    But one more question more ....
    I using ZC Build-in Developer Tools try search "->fields"
    See some example using this
    $somereq=$something->fields;
    Do
    can be
    $req=$yu->fields;
    if(
    this way? if yes, why? or where can find the function define on ZC of this ->filed object?
    Sorry look like a bit more questions, I am still learning PHP, now working on PHP function this learning, for PHP OOP and object I am still a new comer, want to know more ... since I know ZC 1.6 or up will be more OOP way ..
    So, it is time to learning more from this ..
    Thank you of your value time and help.
    Feb 2006
    Tampa Bay, Florida
    Quote Originally Posted by explorer1979 View Post
    Do
    can be
    $req=$yu->fields;
    if(
    This would be different than all the other code you see in Zen Cart. It's really best to keep with the coding standard you see in all the other files.
    swguy,
    Do
    can be
    $req=$yu->fields;
    if(
    When you see the PHP construct $yu->fields within Zen Cart code, there's usually a preceeding call to a $db (database object) function that requests information from the database similar to $yu = $db->Execute ("SELECT <field list> FROM " . TABLE_SOMETHING);
    Each associative array-element of the fields value returned "maps" to an entry in the <field list> of that SQL query.
    Using the above:
    And
    $req2=$yu->fields;
    Then:
    $req===$req2['payment_method']
    The difference is that $req is a single value, where $req2 is an array of values. So there is a bit of a trade-off and potential need for either of these. It would be a waste of memory and related processing time to store the array if the query returns many values but only one is ever used.
    Also, problems can arise in the code if the array is maintained through a long series of code that could potentially modify one or more keys of the variable. By working with one portion of the total the code can typically be easier to follow and modify without impacting the entire program.
    By using the first method as suggested by swguy, the code tends to be easier to read, to understand, and more importantly to debug.
    Feb 2006
    Tampa Bay, Florida
    This is almost certainly more than the OP wanted to know, but:
    There is no additional cost in memory or processing time for method 2. You have already paid the price for retrieving and storing these variables. To reduce memory and processing time, you could change
                    $yu=$db->Execute("SELECT payment_method from required_definitions where payment_method = '".$payment_method."'  ");
    since the field "payment_method" is the only one used.
    That would save the additional overhead of retrieving the additional fields in the required_definitions table.
  1. v155 Problems with your MySQL (mysqli) support
    By Jacques Smit in forum Installing on a Linux/Unix Server
    Last Post: 19 Feb 2024, 09:28 AM
  2. v138a 1064 Error in SQL Syntax - old v.1.3.8 on new MySQL
    By Chasel in forum Installing on a Windows Server
    Last Post: 18 Aug 2012, 07:36 PM
  3. MYSQL vs MYSQLi
    By Bad Dingo in forum Installing on a Windows Server
    Last Post: 9 Aug 2009, 03:43 AM
  4. HELP! Website reverted to old template...can't fix by myself!
    By eschlosser in forum General Questions
    Last Post: 19 Mar 2009, 04:25 PM
