Results 1 to 10 of 96
    Aug 2007
    Amarillo, Tx
    Default How to Add Custom Fields for Materials & Dimensions when adding products?
    Is there an add-on or how to add two custom fields for Materials & Dimensions when adding a new product in the admin area?
    Default Re: How to Add Custom Fields for Metrials & Dimensions when you add products.
    If I am understanding your question then attributes are what you are seeking
    https://www.zen-cart.com/content.php...to-my-products
    Aug 2007
    Amarillo, Tx
    No, I am not looking for attribute. When you go to your add a product page in the Admin area. At the bottom is where you enter your Weight. I want two extra fields for Materials & Dimensions.
    And these will be used for what??
    Aug 2007
    Amarillo, Tx
    It's for Product Details
    Each items has different dimensions & materials over 1,000 items.
    Default Re: How to Add Custom Fields for Materials & Dimensions when adding products?
    You might start with this - it states that it add only one text field but you could alter it for two and it also states that it can be used with tabbed products which I believe your template is using
    https://www.zen-cart.com/downloads.php?do=file&id=926
    Also, you might review this as it allows for additional text based on "tags" entered in your product description
    https://www.zen-cart.com/downloads.php?do=file&id=646
    You might not need the first addon at all
    Aug 2007
    Amarillo, Tx
    Well I looked horrible on both and that isn't what I want.
    Aug 2007
    Amarillo, Tx
    Ok, I tried both what you have discribed and it looked horrible. Take a look at image below. I don't want separate tabs.
    in detail tab what I want is as follows:
    Materials: Iron
    Dimensions: 4" x 4" x 8"
    Model: 10017357
    25 Units in Stock
    Name:  Screen Shot 2016-04-24 at 11.34.21 PM.jpg
    Quote Originally Posted by wmorris View Post
    Materials: Iron
    Model: 10017357
    25 Units in Stock
    So, if understand correctly, were unable to apply either plugin to insert additional information into the single tab. From the picture don't see what is "horrible". If the information makes it to the page then the look of it can be modified using css... if the info doesn't make it there, well then that's a completely different issue. Read-only attributes could provide the same information for which you are looking, but not sure with the "tab" system where they will be presented.
    Aug 2007
    Amarillo, Tx
    Do I really have to use Tabbed Products Pro if I am using Products Extra Fields mod?
  1. Add extra info fields when adding products
    By SethF in forum Templates, Stylesheets, Page Layout
    Last Post: 8 Feb 2012, 06:38 PM
  2. adding custom fields for products
    By jagall in forum Setting Up Categories, Products, Attributes
    Last Post: 24 Apr 2011, 09:52 PM
  3. Add extra shipping charge for Hazardous Materials
    By timhersh in forum Built-in Shipping and Payment Modules
    Last Post: 7 Dec 2008, 06:20 AM
  4. Custom fields for URL & Title
    By BilletMyRide in forum Templates, Stylesheets, Page Layout
    Last Post: 13 Nov 2007, 01:06 AM
