    May 2016
    help question Help Making Tabs Look Better With CSS
    Hey,
    If you scroll down on my practice site you'll see all those ugly looking blue rectangle tabs. Any ideas how I could make these look better? For some reason the text is grey on some and black on others too, which is confusing as hell. The text is centered in some and offset in others. I can post the CSS block in here if that helps too.
    http://www.westnewtonsupply.com
    Default Re: Help Making Tabs Look Better With CSS
    When right-clicking on one of those boxes, my browser gives me an "Inspect" option to use to look at that box's HTML and CSS rules.
    You'll see that they're using 'class="categoryListBoxContents"'.
    So in your CSS you can go find ".categoryListBoxContents" (note: the "." means it's referring to a "class=" for whatever follows it), and make changes there. Or add your own ".categoryListBoxContents" section to the end of your stylesheet to override whatever was set for it earlier.
    I suspect the "some are grey text" refers to your site being configured to display "previously clicked links" (which affects you in your browser, only) in a grey color. You could override this for just these boxes by defining a ".categoryListBoxContents a:clicked" in your stylesheet and setting its properties how you want them.
    I'm intentionally not giving you the complete CSS here, cuz others are better qualified to give you specifics for that. I invite them to chime in.
    In the meantime I hope this helps you get started ;)
    May 2016
    I never got around to replying to this. Thanks for chipping in, this did help a lot. I'm currently struggling to make them clickable, not really sure where I would add the code. I did see a few tutorials online that said to use like.. .CategoryListBoxContent a:hover {padding:0 }; etc.. I tried that and it seemed to make the boxes either vanish completely with the text or it made the boxes smaller and still unclickable. I was doing this in the CSS which is probably the wrong place to do it right? Since that's more for styles/color/size etc, more than controlling what it does.
    display:block often helps to make a larger space clickable
  1. Making website look better on Windows
    By commdiver in forum General Questions
    Last Post: 21 Jan 2011, 06:16 PM
  2. making the column display look better
    By tjthecat3 in forum Setting Up Categories, Products, Attributes
    Last Post: 13 Jan 2008, 08:33 AM
  3. Suggestions on making these products look better?
    By dman76 in forum General Questions
    Last Post: 1 Dec 2007, 07:33 AM
  4. Help with making my Zen cart look like my website
    By laurieudy in forum Templates, Stylesheets, Page Layout
    Last Post: 15 Nov 2007, 03:32 PM
  5. Category 'tabs' that *look* like tabs?
    By Moebiusenterprises in forum Templates, Stylesheets, Page Layout
    Last Post: 4 Oct 2006, 06:52 AM
