Results 1 to 5 of 5
    Feb 2008
    Default Adding products with attributea in cart from product listing
    Hi all
    I have a shop with Zen Cart 1.5 and i am using attributes on some products just for filtering. Attributes don't display on product page, cannot be changed or selected by customer, i just use them for advanced product filtering. The problem is that products with attributes cannot be added in cart from product listing (All products, Specials, Category, etc) and when a customer wants to do a quick add to cart it gets redirected to product page to choose the attribute. Is there any way i can modify the files to ignore the attribute condition and add these products directly to cart? If yes, what are the files i have to modify?
    Default Re: Adding products with attributea in cart from product listing
    When you say just for filtering, are you using the Read-only attribute type that is defined in the option name manager or have you chosen some other form of attribute type?
    If you are using the Read-only type and having this issue of adding product to the cart that have attributes, check the setting of: configuration->attribute settings->Read Only option type - Ignore for Add to Cart. It seems like that should be set to 1.
    Feb 2008
    Thank you very much for this answer. It did the trick :) I was totally ignoring the read-only type, also i didn't know about the ignore option. It seems every day i have something new to learn :)
    Thank you for your answer. This time the solution was simple :) I am bookmarking this topic anyway for just in case :)
    Glad that it helped resolve the issue and broaden your horizons on the capability and operation of ZC!
  1. v155 Problem adding products to cart from product listing page
    By teaj in forum General Questions
    Last Post: 25 Feb 2017, 10:52 PM
  2. v154 Problems when adding to cart from product listing page
    By TinaS in forum Upgrading to 1.5.x
    Last Post: 22 Jan 2015, 01:37 AM
  3. add to cart button on product listing (for products with attributes)
    By easy3dsource in forum Setting Up Categories, Products, Attributes
    Last Post: 10 Apr 2011, 06:08 PM
  4. Products with Attributes / Add to Cart buttons on the Product Listing page?
    By Pink in forum Templates, Stylesheets, Page Layout
    Last Post: 2 Jun 2010, 10:04 PM
  5. Adding Additional Attributes to Product Listing from Custom Product Type
    By Bigman in forum Setting Up Categories, Products, Attributes
    Last Post: 12 Aug 2008, 04:29 PM
