Results 1 to 3 of 3
    Oct 2017
    Troy, NY
    help question Better Together Installation Problem
    I downloaded and unzipped the Better Together module. The folder is called "better" and put it in the root of my application.
    I also tried putting it in the root of my ZenCart which is located in the root of my application.
    When I login to my ZenCart admin and navigate to Modules > Order Total, I only see these:
    Your installation instructions here:
    https://www.thatsoftwareguy.com/zenc...stall_mod.html
    indicate to unzip the files and use an FTP program, not a web based one, so I used FileZilla
    The Better Together installation instructions, here:
    https://www.thatsoftwareguy.com/zenc...l#installation
    indicate "Copy the contents of the unzipped folder to the root directory of your shop."
    Then to login to ZenCart, navigate to Modules > Order Total and you'll see Better Together' listed along with all the other modules available.
    But I do not see it no matter what I do. Please help.
    I normally do installations easily but this is my first ZenCart module installation and I'd like to know what I'm doing wrong.
    Feb 2006
    Tampa Bay, Florida
    Default Re: Better Together Installation Problem
    Copy the includes directory under better to the includes directory of your cart.
    Here's the rookie's guide:
    Oct 2017
    Troy, NY
    Thank you, it's working now!
    Your explanation helped me get my brain back on track. I've worked with Java upgrades in the past but it's been a couple of years!
  1. Better Together Centerbox
    By swguy in forum All Other Contributions/Addons
    Last Post: 27 Nov 2011, 06:21 PM
  2. Better Together Centerbox
    By maryx in forum All Other Contributions/Addons
    Last Post: 23 Jul 2011, 01:24 AM
  3. Better Together add-on
    By CaroleAs in forum All Other Contributions/Addons
    Last Post: 2 Nov 2010, 04:31 PM
  4. Better together issues
    By sheila123 in forum Templates, Stylesheets, Page Layout
    Last Post: 18 Apr 2009, 03:44 AM
  5. Better together problem
    By JasonRSI in forum Addon Payment Modules
    Last Post: 27 Nov 2007, 06:40 PM
