    Jan 2010
    France
    Default Additional Product Images WITH MYSQL 5.7.23 does not work
    Additional Product Images - Version: 2.1
    I'm working locally with mamp pro, mysql version 5.7.23 and php 7.1.22
    When I load an additional image it gives me error 503 and this error log;
    [16-Jan-2019 10:46:56 Europe/Rome] Request URI: /ADMIN/additional_product_images_upload.php?products_id=108&action=insert, IP address: ::1
    #1 trigger_error() called at [/Applications/MAMP/htdocs/MYDOMAINE/includes/classes/db/mysql/query_factory.php:171]
    #2 queryFactory->show_error() called at [/Applications/MAMP/htdocs/MYDOMAINE/includes/classes/db/mysql/query_factory.php:143]
    #3 queryFactory->set_error() called at [/Applications/MAMP/htdocs/MYDOMAINE/includes/classes/db/mysql/query_factory.php:270]
    #4 queryFactory->Execute() called at [/Applications/MAMP/htdocs/MYDOMAINE/Hoist-gzM-Adult/additional_product_images_upload.php:45]
    with mysql version 5.6 everything works fine
    [16-Jan-2019 10:46:56 Europe/Rome] PHP Fatal error: 1364:Field 'category_id' doesn't have a default value :: insert into additional_images
    (products_id, additional_image, status)
    values ('108',
    'additional/myimage.jpg',
    '1') ==> (as called by) /Applications/MAMP/htdocs/MYDOMAINE/ADMIN/additional_product_images_upload.php on line 45 <== in /Applications/MAMP/htdocs/MYDOMAINE/includes/classes/db/mysql/query_factory.php on line 171
    $db->Execute("insert into " TABLE_ADDITIONAL_IMAGES "
                        values ('"
    zen_db_input((int)$_GET['products_id']) . "',
    $additional_image_name "',
                                '1')"
    Thanks for your help
    Giovanni,
    Zen Cart V2.1
    Dec 2009
    Amersfoort, The Netherlands
    Default Re: Additional Product Images WITH MYSQL 5.7.23 does not work
    You can solve that by going to your phpmyadmin (or equivalent) and add a default value of 0 to categories_id in the table structure of additional_images.
    This a new feature on mysql5.7, where a integer field needs a value in the query, or else it will fail, unless you have set a default value.
    Quote Originally Posted by diamond1 View Post
    values ('108',
                        values ('"
                                '1')"
    Jan 2010
    France
    It worked!!
    You are a magician Thanks
    How did you understand that I had to put null default value of null to categories_id?
    I confirm it works also with the lower version mysql 5.5 and 5.6
    Thanks ZZZ if one day passes from Brussels contact me we take a coffee
    Giovanni,
    Zen Cart V2.1
    Dec 2009
    It was not that hard, as it is a common problem on newer mysql versions.
    By the way it should be 0, not null, as the field expects an integer, and null is not an integer.
    Thanks for the invitation .
  1. Additional Images does not show on product page
    By XxDrAg0nxX in forum Templates, Stylesheets, Page Layout
    Last Post: 23 May 2009, 04:00 PM
  2. Ultimate SEO URLs Does Not Work with Categories with Only One Product
    By hossbronco in forum All Other Contributions/Addons
    Last Post: 17 Oct 2008, 04:03 AM
  3. USPS Does not work with Zone selected
    By Hound in forum Built-in Shipping and Payment Modules
    Last Post: 5 Jan 2008, 05:43 AM
  4. Does ZC work with MySql 5.x?
    By ckosloff in forum Installing on a Windows Server
    Last Post: 9 May 2007, 03:08 PM
