Results 1 to 10 of 10
    Apr 2023
    UK
    Default How To Get Schema Output For Products
    Running the latest version of Zencart and would like to know how to get schema output for products. Currently there is no schema being shown for anything on the site. Not sure if we need a specific plugin for this. Had a look and can't see any recent plugins for this.
    Any help would be greatly appreciated!
    Kind Regards,
    Andy
    Default Re: How To Get Schema Output For Products
    Log into your webhost's cPanel and navigate to the phpMyAdmin tool.
    From that tool, select your site's live database. You'll see a list of tables and one of the selections for each table will be "Structure" (aka schema).
    Feb 2006
    Tampa Bay, Florida
    Also, the schemas are included in the documentation and can be built using the View Schema plugin.
    https://docs.zen-cart.com/dev/schema/
    Aug 2007
    Gijón, Asturias, Spain
    Perhaps the OP actually means Schema as in structured data....in which case:
    https://www.zen-cart.com/showthread....-Graph-Twitter
    use Github version.
    Steve
    github.com/torvista: BackupMySQL, Structured Data, Multiple Copy-Move-Delete, Google reCaptcha, Image Checker, Spanish Language Pack and more...
    Feb 2006
    Tampa Bay, Florida
    Ah! I suspect you're right after rereading the first post. Let's see what the OP says.
    Apr 2023
    UK
    Thanks for all the responses everyone. Still not sure how we can actually get our products to be outputting the relevant information for products, e.g: price, stock status: in stock / out of stock etc. Have read the following link:
    which says that the latest versions are built with the view schema plugin, but not sure if there is some setting from within Zencarts admin, which needs to be set up for schema to work, or whether we need to find another plugin for schema, or whether we need to add some code to the website somewhere, for schema to work?
    Any other suggestions, would be very much appreciated!
    Kind Regards,
    Andy
    Feb 2006
    Tampa Bay, Florida
    Look at @torvista's response - that will give you what you want. This is a plugin you will need to install and customize to your requirements.
    Apr 2023
    UK
    Thanks torvista. Downloaded the Github version and have got this running. Great plugin by the way. Works really well. One very minor thing that we have noticed, is that all of our products are showing aggregateRating > rating value: 3
    Not sure why it's showing a value of 3, as we have no product reviews yet.
    Kind Regards,
    Andy
    Aug 2007
    Read the Readme again: Reviews.
    Steve
    Apr 2023
    UK
    Thanks Torvista,
    Apologies for missing this in the readme file.
    All sorted now!
    Kind Regards,
    Andy
  1. Replies: 13
    Last Post: 27 Jun 2019, 05:31 AM
  2. How to get rid of "New Products for June" box
    By pace in forum General Questions
    Last Post: 3 Jun 2010, 11:09 PM
  3. Replies: 1
    Last Post: 30 Oct 2009, 05:46 PM
