I am using ZC 1.3.7 and wanted the same thing. I copied the entire product_notifications sidebox page and pasted it into the <!--bof Add to Cart Box --> on the tpl_product_info_display page
it seems to work ok. Please post if there is a better way.
* product_notifications sidebox - displays a box inviting the customer to sign up for notifications of updates to current product
* @package templateSystem
* @version $Id: product_notifications.php 2993 2006-02-08 07:14:52Z birdbrain $
// test if box should show
$show_product_notifications = false;
if (isset($_GET['products_id']) and zen_products_id_valid($_GET['products_id'])) {
if (isset($_SESSION['customer_id'])) {
$check_query = "select count(*) as count
from " . TABLE_CUSTOMERS_INFO . "
where customers_info_id = '" . (int)$_SESSION['customer_id'] . "'
and global_product_notifications = '1'";
$check = $db->Execute($check_query);
if ($check->fields['count'] <= 0) {
$show_product_notifications= true;
if ($show_product_notifications == true) {
if (isset($_GET['products_id'])) {
from " . TABLE_PRODUCTS_NOTIFICATIONS . "
where products_id = '" . (int)$_GET['products_id'] . "'
and customers_id = '" . (int)$_SESSION['customer_id'] . "'";
$notification_exists = (($check->fields['count'] > 0) ? true : false);
$notification_exists = false;
if ($notification_exists == true) {
require($template->get_template_dir('tpl_yes_notifications.php',DIR_WS_TEMPLATE, $current_page_base,'sideboxes'). '/tpl_yes_notifications.php');
require($template->get_template_dir('tpl_no_notifications.php',DIR_WS_TEMPLATE, $current_page_base,'sideboxes'). '/tpl_no_notifications.php');
$title = BOX_HEADING_NOTIFICATIONS;
$box_id = 'productnotifications';
$title_link = false;
require($template->get_template_dir($column_box_default, DIR_WS_TEMPLATE, $current_page_base,'common') . '/' . $column_box_default);
