    Jan 2005
    Mosquito Coast, Texas
    Problem with EZPages
    So I have customized my cart, but I cannot get the EZPages to show in the footer. Perhaps I have misunderstood something, but I thought you could specify pages to appear in either the footer or the header. The pages show in the header, but none of the footer pages show. Help?
    I have the sort order starting at 5 for the footer, All the boxes except FOOTER turned off.
    http://www.darkswan.com/store
    Jan 2005
    Default Re: Problem with EZPages
    Nevermind, I found the problem. The tpl_footer didn;t have the code for the ezpage footer.
    Are you positive that you needed to edit a file for this???
    In the admin you can enable EZ Pages...
    Jan 2005
    The ezpages were enabled. THe problem was I used the Classic template tpl_footer in the common files and the footer does not have the ezpages footer code on it.
    I opened the tpl_footer in the template_default directory and copied the code for the ezpages footer over. It works fine now
  1. v154 Problem with Ezpages side box
    By dfontana in forum General Questions
    Last Post: 12 May 2015, 07:16 PM
  2. Problem with ezpages on site map
    By Halollet in forum General Questions
    Last Post: 15 Aug 2010, 07:31 PM
  3. Multilingual Ezpages problem
    By nilsen in forum Templates, Stylesheets, Page Layout
    Last Post: 31 Jan 2009, 12:54 AM
  4. 1.3.6 upgrade problem with ezpages
    By kookiewookie in forum Upgrading from 1.3.x to 1.3.9
    Last Post: 2 Nov 2006, 10:09 AM
  5. problem with EZpages
    By whiteboxer in forum Basic Configuration
    Last Post: 2 Aug 2006, 12:34 AM
