I made a test buy and SSL is not working when I put in the credit card numbers even though SSL has been configured.![]()
When I log in to the admin, it is working fine. Can somebody please tell me how to fix the problem?
Virtue
Virtue
Virtue
got a URL to look at?
Who is your host?
have you manually added any images?
do you run a tracking code like from google?
The site is not done yet. I am still trying to make some changes with the layout. But I am not worried about that yet. I am more concerned with the security as of the moment.
Here's the url
http://exophora.com/e-store/index.php?main_page=index
I am wondering why I am not seeing the https:// when I tried to make a test buy. My host is advancehostnetwork. They already configured it for me. The tech support mentioned about setting a cookie to make this to work? I am new to this ssl thing, so I really don't know what to say.
If you can do something please help.
Virtue
Virtue
it would seem that the includes/configuration.php
is not configured properly,
It needs to define the shared ssl URL and the ssl switch needs to be set to true....
The reason I asked about images or tracking software is if not done properly these can actually break SSL
and the reason I asked about host is certain hosts ( godaddy and others ) require a change in the core code to work
Hi Merlin,
Okay I am copying the lines wherein we changed the configuration. Can you please tell me what is wrong?
Please see below codes. Thanks:
define('HTTP_SERVER', 'http://exophora.com');
define('HTTPS_SERVER', 'https://ssl127.securednshost.com/~exophora');
define('HTTP_CATALOG_SERVER', 'http://exophora.com');
define('HTTPS_CATALOG_SERVER', 'https://ssl127.securednshost.com/~exophora');
define('DIR_WS_ADMIN', '/e-store/admin/');
define('DIR_WS_CATALOG', '/e-store/');
define('DIR_WS_HTTPS_ADMIN', '/e-store/admin/');
define('DIR_WS_HTTPS_CATALOG', '/e-store/');
Virtue
Something is not configured correctly as your site is not changing to SSL when it should.
Perhaps this FAQ will help. http://www.zen-cart.com/forum/faq.ph...configure_ssl_
that is only the admin configuration file
you missed the
includes/configure.php
We followed exactly what it said.
I didn't see instructions for a shared SSL.
I am thinking of adding this code, am guessing:
define('HTTPS_SERVER', 'https://ssl127.securednshost.com/~exophora/e-store');
Virtue
Dont add anything
please follow the instructions in your PM
you only modified 1 of the 2 config files,
the one you posted is from the admin
just make the changs to the catalog side and you will be all set
Here's the other modification we made from includes/configure.php. Am I missing something? Or is there something wrong? I made a test buy using a dummy card number through linkpoint it went through perfectly, but still it didn't call the SSL security during the test buy. Please check the coding below. I truly appreciate any further help. Thanks.
define('HTTP_SERVER', 'http://exophora.com:80');
define('ENABLE_SSL', 'yes');
Virtue
