hareslade
fortuna
I'm using the purpleshades 1.3 too, there's some sort of a hiccup in the common/tpl_header.php, if you compare the file code, its not same as my 1.3.2 equivalent standard downloaded zencart 1.3.2 file in terms of i.d version....
I think its out of date, on mine I get a 'no_picture' picture stuck underneath the product lists (or any other page)
I can't locate where the 'no pic' comes from, but by the pic, in the page html is
<!--bof-optional categories tabs navigation display-->
(and eof the same) which definately should be in the header html, not down the bottom..
I assume you've found it already, but you're right -- 1.3.2 has some differences. Change
<?php echo zen_display_banner('static', $banner); ?>
<a href="<?php echo zen_href_link(FILENAME_DEFAULT, '', 'NONSSL'); ?>">
<?php echo HEADER_TITLE_CATALOG; ?></a>
in \includes\templates\purpleshades\common\tpl_footer.php
to fix the 'no_picture' picture stuck underneath the product lists (or any other page)
