Results 1 to 10 of 12
    Feb 2006
    Default Display Problem after upgrade
    While upgrading from the previous version to the 3.1.0.1, I have also installed the corresponding french language pack. I now have displaying issues that weren't there before.
    With EXPLORER
    The french version does not show the accents, they look like chinese caracters. However, if I insert an accent in the english page, they show with any problem.
    With FIREFOX
    On the top left corner, the following caracters appear : »¿ï»¿ï»¿ï»¿. However, the french accents appear correctly...
    In both BROWSERS
    The logo and the language flags are surrounded with a border that was not there in the previous version.
    Site's url www.advitam.com
    Can anyone help ?
    Pierre
    Jun 2003
    Default Re: Display Problem after upgrade
    Feb 2006
    No the language looks like it's correctly defined in french.php.
    Furthermore, funnily enough accents do appear correctly in firefox on one hand, and in both explorer and firefox in the english pages. I put accents on my english home page and they appear correclty.
    Any other ideas ?
    Pierre
    Feb 2006
    Even if I delete french.php. And I copy english.php into french.php, the problem remains. Accents are visible on the english version, not on the french.
    Don't understand what's happening but it doesn't seem like it comes from this file.
    Feb 2006
    When I replace the special caracters by their entities (http://www.tcd.ie/html/char.html) then the page appears correctly. I don't really understand.
    Feb 2006
    two days spent sorting this out.
    I went back to the previous release. The french pack is not ready.
    Aug 2004
    Does your charset has been properly configured from your french.php and differently from your english.php file ?
    Feb 2006
    yes, definiitely.
    But funnily, if I put accents in the english pages, they appear correctly.
    Feb 2006
    Solution.
    For those interested, I experienced too many problems with the french version developped by Jean Gourdon. I downloaded another translation developed by "Oeildefeu" on the french zencart support site, and everything seems to be working smoothly.
    Pierre
    Aug 2004
    Great thanks for this update. It will also be useful, for me, since I was already working on the updated translations of the french pack in order to fit in the latest releases of Zen Cart.
  1. Problem after upgrade
    By gabenn2 in forum Setting Up Categories, Products, Attributes
    Last Post: 7 Feb 2008, 12:14 PM
  2. Product display problem after upgrade
    By TouranMan in forum Upgrading from 1.3.x to 1.3.9
    Last Post: 22 Jan 2007, 11:14 PM
