Results 1 to 10 of 10
    Apr 2006
    Sofia, Bulgaria
    Zen cart wont work with virtual host ?
    Pleasseee I already dont know what a hell is going on here
    i cant configure my cart to use mu VHost ...
    here is the configure.php file
    define('HTTP_SERVER', 'e-storebg.com/');
      define('HTTPS_SERVER', 'e-storebg.com/');
      define('DIR_WS_CATALOG', 'e-storebg.com/');
      define('DIR_WS_HTTPS_CATALOG', 'e-storebg.com/');
      define('DIR_FS_CATALOG', 'C:/apache2triad/htdocs/e-storebg.com/');
    and here is the httpd.conf
    NameVirtualHost www.e-storebg.com
    <VirtualHost www.e-storebg.com>
        ServerAdmin [email protected]
        DocumentRoot C:/apache2triad/htdocs/e-storebg.com
        ServerName www.e-storebg.com
        ServerAlias e-storebg.com
        DirectoryIndex index.php
        ErrorLog C:/apache2triad//logs/www.e-storebg.com-error.log
        CustomLog C:/apache2triad//logs/www.e-storebg.com-access.log combined
    </VirtualHost>
    it wont work shows me links in apache like : ...,
    http://e-storebg.com/e-storebg.com/e...=index&cPath=1......
    Im Using
    Apache/2.0.55 (Win32) PHP/4.4.2 mod_ssl/2.0.55 OpenSSL/0.9.8a
    OS: Windows Advanced Server 2003 R2
    Zen Cart v 1.3x
    Also Im behing router which IP is: 193.68.140.40
    Domain DNS is also like this on router this is not a problem but I dont know
    I cant get it pleaseee anyy one
    Apr 2006
    Sofia, Bulgaria
    Default Re: Zen cart wont work with virtual host ?
    ok I found out how to configure Apache and I did it know the store is working
    but https wont work OK when I decide to log into profile or chust to check out it wont load
    the apache is ok it cant be problem something is in the zencart I dont
    I made it same congig and for 443 port but it wont work
    what I miss and where ?
    Nov 2004
    Norfolk, United Kingdom
    Go to your Zen Cart admin panel --> Tools --> Server Info and scroll down until you find the Open SSL entries. That will tell you if ssl is installed or not.
    Also, make sure that you have ssl enabled in both of your configure.php files.
    Vger
    Apr 2006
    Sofia, Bulgaria
      define('ENABLE_SSL', 'true');
    I have this I have SSL I mean it works but when I click to login
    It wonts to display the page I have one more errors at the apache
    In the ssl error log i Found this
    [Thu Jun 15 19:14:46 2006] [warn] RSA server certificate CommonName (CN) `localhost' does NOT match server name!?
    So i know that this is not for this forum but how could I manage my certificates how could i genarate one or what .. i dont know
    Nov 2004
    What is your server name then? Once you know that you can change your local configure.php files to match it and the ssl problems should be resolved. It may be that your server uses 127.0.0.1 (the ip address for localhost), or the ip address of a router attached your computer, or even the name of a computer on a network.
    Vger
    Apr 2006
    Sofia, Bulgaria
    I got it the problem isn't in the Zen Cart I have problems with certificates by apache I have to ganarate Certificate wich name has to match with that on one Server name (the same as its site and domain name).
    This is really confusing couse I generate it but i can't find where my apache save them I already posted to their forum but still no answer.
    If any one have expirience with that Should be great to help.
    Sorry about the offtopic but Im going to overload and I need some help but noone pay attention I read out all toturials and help files but still nothing
    I will be grateful for any help gaved ?
  1. Migrating to new host using SuPhp - admin login wont work!
    By photoseller in forum General Questions
    Last Post: 12 Jul 2010, 04:45 PM
  2. Can zen cart be used with virtual merchant
    By amonte in forum General Questions
    Last Post: 26 Jun 2008, 07:21 PM
  3. Host site not compatible with Zen Cart?
    By missterri in forum General Questions
    Last Post: 16 Apr 2008, 04:50 PM
  4. moving zen cart to a virtual host with no domain
    By Capslock118 in forum General Questions
    Last Post: 26 Jun 2007, 09:48 PM
  5. Total Confuse with virtual host
    By sicness in forum General Questions
    Last Post: 12 Jun 2006, 03:29 PM
