Results 1 to 10 of 11
    Problems with Installation
    I installed yesterday for the first time and I could get to the admin section, but not the store. So I looked around here and realized I didn't ftp all the install files. So, I went ahead and installed again, this time I used SSL. At the end of the install when I click to go to admin I get a warning saying the certificate doesn't match the intended username. I can get past that and it says I've installed a new certificate. When I try to go to the admin though I get the 404 error. I am also getting that when I click to check the store. My website is www.thehappiestkids.com Please help!
    Default Re: Problems with Installation
    It appears that the information you entered for SSL support is not correct.
    To work around it for now, you can edit your configure.php files to disable the SSL support for the time being. This post should help you do that:
    http://www.zen-cart.com/forum/showpo...66&postcount=6
    Thank you. I changed those files and I can get to the admin area now. When I try to click on go to store I get The Page cannot be found http 404 error.
    Sounds like you missed a setting.
    Please post both your /includes/configure.php and /admin/includes/configure.php files without passwords
    Thank you very much!! Here you go
    define('HTTP_SERVER', 'http://thehappiestkids.com');
    define('HTTPS_SERVER', 'https://thehappiestkids.com');
    define('DIR_WS_PHPBB', '/');
    define('DIR_FS_CATALOG', '/home/thehappi/public_html/');
    define('DB_TYPE', 'mysql');
    define('DB_PREFIX', 'thehappi_');
    define('DB_SERVER', 'localhost'); // eg, localhost - should not be empty
    define('DB_SERVER_USERNAME', '');
    define('DB_SERVER_PASSWORD', ');
    define('DB_DATABASE', 'thehappi_zencart');
    define('STORE_SESSIONS', 'db'); // leave empty '' for default handler or set to 'db'
    define('DIR_FS_SQL_CACHE', '/home/thehappi/public_html/cache');
    // Main webserver: eg, http://localhost - should not be empty for productive servers
    // HTTP_CATALOG_SERVER is your Main webserver: eg, http://www.yourdomain.com
    // HTTPS_CATALOG_SERVER is your Secure webserver: eg, https://www.yourdomain.com
    define('HTTP_CATALOG_SERVER', 'http://thehappiestkids.com');
    define('HTTPS_CATALOG_SERVER', 'https://thehappiestkids.com');
    define('DIR_WS_ADMIN', '/admin/');
    define('DIR_WS_HTTPS_ADMIN', '/admin/');
    define('DIR_FS_ADMIN', '/home/thehappi/public_html/admin/');
    define('DB_SERVER_USERNAME', ');
    I don't see anything immediately wrong there.
    If you go to the site's main URL , does it work properly?
    Is it only when clicking "Online Catalog" from the admin area that you encounter the 404 message?
    Yes, it works fine at the mail URL. I only get the message from the online catalog.
    The site itself works fine, but the store isn't there. You can see the website I built, but not the store.
    I checked my error log on the server and I was getting this when I tried going to my store.
    Wed Jun 28 07:10:04 2006] [error] [client 65.93.149.55] File does not exist: /home/thehappi/public_html/store [Wed Jun 28 07:10:00 2006] [error] [client 65.93.149.55] File does not exist: /home/thehappi/public_html/shop [Wed Jun 28 07:09:41 2006] [error] [client 65.93.149.55] File does not exist: /home/thehappi/public_html/favicon.ico [Wed Jun 28 04:55:17 2006] [error] [client 71.100.0.69] File does not exist: /home/thehappi/public_html/zc_install/index.php [Wed Jun 28 04:55:16 2006] [error] [client 71.100.0.69] File does not exist: /home/thehappi/public_html/zc_install/index.php [Wed Jun 28 04:55:14 2006] [error] [client 71.100.0.69] File does not exist: /home/thehappi/public_html/zc_install/index.php [Wed Jun 28 04:55:11 2006] [error] [client 71.100.0.69] File does not exist: /home/thehappi/public_html/zc_install/index.php [Wed Jun 28 04:55:02 2006] [error] [client 71.100.0.69] File does not exist: /home/thehappi/public_html/index.php [Wed Jun 28 04:47:45 2006] [error] [client 71.100.0.69] File does not exist: /home/thehappi/public_html/index.php [Wed Jun 28 04:47:42 2006] [error] [client 71.100.0.69] File does not exist: /home/thehappi/public_html/index.php [Wed Jun 28 04:47:18 2006] [error] [client 71.100.0.69] File does not exist: /home/thehappi/public_html/index.php [Wed Jun 28 04:47:15 2006] [error] [client 71.100.0.69] File does not exist: /home/thehappi/public_html/index.php [Wed Jun 28 04:46:31 2006] [error] [client 71.100.0.69] File does not exist: /home/thehappi/public_html/index.php
    so, I copied over my index.php file to public_html and zc_install. I can't find a file or directory named shop anywhere. I'm either missing it or just not looking in the right place. When I go to the store now, I'm getting this error message
    Warning: main(includes/languages/english.php): failed to open stream: No such file or directory in /home/thehappi/public_html/includes/init_includes/init_languages.php on line 26
    Fatal error: main(): Failed opening required 'includes/languages/english.php' (include_path='.:/usr/local/lib/php') in /home/thehappi/public_html/includes/init_includes/init_languages.php on line 26
    Something seems to be wrong with my languages file too. I had to copy english.php over to the English folder manually. Can I just re-install the languages folder? and the store folder if I need that too?
    Sounds like you had a bad upload and many of the files are missing.....
    Some FTP programs are bad for timeouts.
    FileZilla (filezilla.sf.net) is free and I've heard no complaints about its reliability.
    I suggest re-uploading the files to your site.
  1. Problems with installation
    By bmw2182 in forum Installing on a Linux/Unix Server
    Last Post: 1 Aug 2008, 05:32 PM
  2. Problems with Thunderbird installation
    By Marlake in forum Installing on a Windows Server
    Last Post: 9 Apr 2008, 09:53 PM
  3. Problems with installation in cPanel
    By icnmcotto in forum Installing on a Linux/Unix Server
    Last Post: 8 Nov 2007, 05:14 PM
