Results 1 to 3 of 3
    Nov 2003
    External Order Numbers Generator - different customers using Same Order ID on Authnet
    Hi All
    When using this contrib (thanks, JeffD!), what happens when one customer tries but fails to create an order, then a few minutes later, a second customer comes along and then creates an order using that same order ID that the first customer failed to create an order with?
    1. "Customer A" tries twice to create order 1234, but payment processor (Authnet_AIM) declines this twice (cuz of AVS mismatch)
    2. "Customer B" comes along a few minutes later. Customer B successfully creates order 1234 using totally unique cc info and billing info.
    Is there anything that should be of concern about this? Does this create any confusion, etc.?
    The order history in the Authnet admin shows all transactions, failed and successful.
    Many thanks :-)
    Sep 2004
    Default Re: External Order Numbers Generator - different customers using Same Order ID on Authnet
    Hi All,
    Yes, what you describe Dogtags is a distinct possiblility that can happen this way but should not cause a problem that I am aware of. Here's what happens...
    Cust A is goes to AIM module and generates an EONG orders_id. He is declined
    (even n times, but reuses that orders_id since it is attached to his session). The orders_id is locked and assigned to him thoughout the authorization process but as soon as AIM declines the orders_id is marked for reuse, removed from his session and returned back to the pool.
    Cust B during this time places an order, he will get the same orders_id (since until an order with this orders_id is written to the orders table, will be reused). As soon as the order is written, then the next orders_id will be used/generated. If Cust A attempts to place another order, he will get a new orders_id.
    Does this make sense?
    Jeff
    Nov 2003
    Thanks so much for the explanation, Jeff. This is great :-)
  1. Replies: 12
    Last Post: 5 Jul 2013, 07:54 AM
  2. Same order status updated twice with different comments
    By quick1 in forum General Questions
    Last Post: 19 Jun 2011, 11:09 PM
  3. Replies: 2
    Last Post: 27 Oct 2010, 01:45 PM
  4. Looking for the External Order Number Generator
    By ARCANE in forum All Other Contributions/Addons
    Last Post: 11 Aug 2010, 05:29 PM
  5. 2 customers order same item (1 in stock) and checkout successfully
    By ColourfulDesigns in forum General Questions
    Last Post: 31 Jul 2010, 10:09 PM
