    May 2005
    Problem to access zen store from a LAN
    I'm trying to access my zec cart store from a remote pc in my LAN but I'm finding some problems with it.
    My zen store is ok, and worksa just fine, in the server pc, but I cannot access it from another pc. I tried changing the IP adress but it was no good.
    Can you give some help/tips to solve this problem?
    Many thanks,
    jc
    May 2004
    Hong Kong
    Default Re: Problem to access zen ztore fram a LAN
    May be the following topic related to your problems.
    Works On The Server, No Where Else! (using small internal network LAN)
    A New Starter again
    May 2005
    I've made the IP changes on the configure.php (on the 4 times localhost is shown) but I cannot access it yet from a remote machine?
    Is there any other thing I must do, or it was just changing the IP address?
    thks
    May 2005
    Quote Originally Posted by seethrou
    thks
    Feb 2006
    Chicago
    Before doing anything else, do this thing
    Make a folder test where you have zencart installed and place a test html file there
    Try to see if you can access it from the other machines and let us know
    Idea or Suggestion Re: Problem to access zen ztore fram a LAN
    EXAMPLE LAN configuration:
    A. Server, with IP address of: 192.168.0.33
    B. PC's, with IP addresses of: 192.168.0.51, 192.168.0.52, 192.168.0.53, 192.168.0.54, 192.168.0.55, etc
    NEED:
    - To access server content from PC's
    - To access server content from server
    HOW:
    - includes/configure.php define('HTTP_SERVER', '192.168.0.33');
    - includes/configure.php define('ENABLE_SSL', 'false');
    - includes/configure.php define('DATABASE_SERVER', 'localhost');
    - admin/includes/configure.php define('HTTP_SERVER', '192.168.0.33');
    - admin/includes/configure.php define('HTTP_CATALOG_SERVER', '192.168.0.33');
    - admin/includes/configure.php define('ENABLE_SSL_CATALOG', 'false');
    - admin/includes/configure.php define('ENABLE_SSL_ADMIN', 'false');
    - admin/includes/configure.php define('DATABASE_SERVER', 'localhost');
    ACCESSING:
    - From the PC or from the server, open your site in your browser via: http://192.168.0.33
  1. Can't access my store after upgrading from 1.3.9f to g to h
    By Sarah808 in forum Upgrading from 1.3.x to 1.3.9
    Last Post: 6 Oct 2011, 05:50 PM
  2. user blocked access from zen store
    By ejhernandez in forum General Questions
    Last Post: 30 Dec 2008, 03:06 PM
  3. Not resolving from my LAN
    By pfristoe in forum Installing on a Linux/Unix Server
    Last Post: 10 Jul 2008, 04:30 AM
  4. No CSS from LAN
    By ebtech in forum Installing on a Linux/Unix Server
    Last Post: 22 Oct 2007, 07:20 AM
