Page 1 of 3 123 LastLast
Results 1 to 10 of 29
    Miramar, FL
    Default Need HELP please!
    I have been trying for the past 2 days to install zencart and to no avail. I've uploaded and deleted files so many times that I've lost count. After going through the installation I receive this message when I go to the site - www.mykeepsakekreations.com:
    Warning: main(includes/application_top.php): failed to open stream: Permission denied in /home/content/j/f/u/jfullermkk/html/index.php on line 26
    Fatal error: main(): Failed opening required 'includes/application_top.php' (include_path='.:/usr/local/lib/php') in /home/content/j/f/u/jfullermkk/html/index.php on line 26
    On the index.php page this is what's on line 26:
    I get this message in the admin:
    Warning: main(/home/content/j/f/u/jfullermkk/html/includes/autoload_func.php): failed to open stream: Permission denied in /home/content/j/f/u/jfullermkk/html/admin/includes/application_top.php on line 145
    Fatal error: main(): Failed opening required '/home/content/j/f/u/jfullermkk/html/includes/autoload_func.php' (include_path='.:/usr/local/lib/php') in /home/content/j/f/u/jfullermkk/html/admin/includes/application_top.php on line 145
    On the admin/includes/application_top.php page this is what's on line 145:
    require(DIR_FS_CATALOG . 'includes/autoload_func.php');
    Would someone please help me??? I am so FRUSTRATED with this and don't know how to fix the problem. I feel like giving up if this is going to take me another 2 days to try and figure out. Thanks in advance!
    Feb 2006
    Chicago
    Default Re: Need HELP please!
    This seems to be file permission issue
    Make sure you have 755 permission set for files!
    further, please post your /includes/configure.php file contents, without the password
    Aug 2004
    Since this is, also, about a permission denied error message, you can also check the installation documentation, from the docs folder, of the latest Zen-Cart package version you have downloaded. It will specify which permission settings needs to be set in order to run Zen-Cart properly.
    Nov 2004
    Norfolk, United Kingdom
    Quote Originally Posted by superprg
    Make sure that you DO NOT have permissions of 755 set for files. There's no need to have any files with permissions higher than 644.
    Vger
    Aug 2004
    Except during the Zen-Cart installation process:
    - includes/configure.php
    - admin/includes/configure.php
    files needs to be set to CHMOD 666 on most web servers. Otherwise, these two files won't be able to be written automatically once the installation will be nearly completed.
    Nov 2004
    This is a post-install problem. For the install itself I'd recommend 755 on those two files, and reset afterwards to 644 on Windows servers, or 444 or 400 on Apache.
    It seems that the problem is related to permissions on the 'includes' folder. Please check that they are 755.
    Vger
    Miramar, FL
    Thanks so so much guys for responding so quickly. I installed ZenCart back in May for another business, and it is working just fine, and I did the same steps for this install and it won't work. Permissions on the configure.php files were set to 644 after install.
    Here's the admin/includes/configure.php contents:
    // Main webserver: eg, http://localhost - should not be empty for productive servers
    // HTTP_CATALOG_SERVER is your Main webserver: eg, http://www.yourdomain.com
    // HTTPS_CATALOG_SERVER is your Secure webserver: eg, https://www.yourdomain.com
    define('HTTP_SERVER', 'http://mykeepsakekreations.com');
    define('HTTPS_SERVER', 'https://mykeepsakekreations.com');
    define('HTTP_CATALOG_SERVER', 'http://mykeepsakekreations.com');
    define('HTTPS_CATALOG_SERVER', 'https://mykeepsakekreations.com');
    define('DIR_WS_ADMIN', '/admin/');
    define('DIR_WS_HTTPS_ADMIN', '/admin/');
    define('DIR_FS_ADMIN', '/home/content/j/f/u/jfullermkk/html/admin/');
    define('DIR_FS_CATALOG', '/home/content/j/f/u/jfullermkk/html/');
    define('DB_TYPE', 'mysql');
    define('DB_PREFIX', '');
    define('DB_SERVER', 'mysql99.secureserver.net'); // eg, localhost - should not be empty
    define('DB_SERVER_USERNAME', '');
    define('DB_SERVER_PASSWORD', '');
    define('DB_DATABASE', 'keepsake');
    define('STORE_SESSIONS', 'db'); // leave empty '' for default handler or set to 'db'
    define('DIR_FS_SQL_CACHE', '/home/content/j/f/u/jfullermkk/html/cache');
    For some reason I have not been able to access the includes/configure.php file. I keep getting a little 'x' next to the file and an error message that says "Can't change the directory to /includes: Permission denied".
    Aug 2004
    Very well. Please post your URL pointing to your techsupp.php file.
    Note: You will find this file from your downloaded package within the zc_install folder.
    Miramar, FL
    I was only able to enter 14000 characters so I had to cut the file contents in half and post twice.
    <file contents removed for sake of brevity>
  1. v150 I need help with my product listing please help im going insane!!
    By Darion in forum Templates, Stylesheets, Page Layout
    Last Post: 10 Sep 2012, 04:16 AM
  2. v150 I need help with my product listing please help im going insane!!
    By Darion in forum General Questions
    Last Post: 10 Sep 2012, 02:12 AM
  3. please help need help for reviews and tips page
    By abs007 in forum General Questions
    Last Post: 9 Apr 2009, 02:14 PM
  4. Need help with color scheme - URGENT PLEASE HELP
    By nepton in forum Templates, Stylesheets, Page Layout
    Last Post: 18 Nov 2008, 03:48 AM
  5. Mcafee scan says I need to fix I need help please??
    By touchclothing in forum General Questions
    Last Post: 30 Sep 2008, 08:57 PM
