    Jun 2006
    Default product alignment problems
    hey, im having a hardtime aligning the subcategory images and the product images. my site is www.driventorise.com/test
    1) when you click on Jeans, you will see the subcategory images. i would like to set that up so it comes up 2 and 2 or 3 and 1 centered, ect.
    2) the new products arent coming in aligned properly. there will be one a line then two on a line. where can i set this up so i can evenly place 3 products on each line?
    3) also, how can i remove the text below each subcategory image
    May 2004
    Hong Kong
    Default Re: product alignment problems
    First, you have the images larger and at least negected the total width provided sufficient or not.
    For your Q#1 and Q#2, you can either,
    1. wider the page width
    -- providing more width in total
    2. wider the centerBoxContents
    -- by reduce the width of the 2 side columns, then have a wider centerBoxContents
    3. reduce the width of images,
    or, reduce the margins width of the images boxes by adding the following negative values to your css and adjust them until fit,
    /* For Center Box Contents, not in rows in Index Page */
    .centerBoxContentsNew, .centerBoxContentsFeatured, .centerBoxContentsSpecials {
    margin-left: -0.5em;
    margin-right: -0.5em;
    /* For SubCategories Listing not in Rows */
    .categoryListBoxContents {
    float: left;
    For your Q#3.
    What happen if by chances some subcategories images missed?
    (may be by human errors, network problems...!)
    A New Starter again
    Jun 2006
    thanks a lot, its working now
    the text under the subcategory image, like after you click on Jeans, and then i have 4 subcategories. i want it to just show the picture
    May 2004
    Hong Kong
    Quote Originally Posted by rcallan515
    DrByte had given answer in another thread, for removing the link text under the Subcategory Icon images.
    If other people with similar need, please refer to the thread below for details:
    Post #8 - Re: centerboxwrapper trouble
    A New Starter again
  1. Alignment problems
    By UnknownImp in forum Templates, Stylesheets, Page Layout
    Last Post: 20 Jan 2011, 11:44 PM
  2. Alignment problems in IE
    By rcallan515 in forum General Questions
    Last Post: 19 Sep 2006, 12:42 AM
  3. Alignment Problems
    By e-hol.co.uk in forum Templates, Stylesheets, Page Layout
    Last Post: 23 Jul 2006, 11:37 PM
  4. product alignment problems
    By rcallan515 in forum All Other Contributions/Addons
    Last Post: 23 Jul 2006, 09:16 AM
