Results 1 to 10 of 11
    Dec 2004
    Redcliffe QLD, Australia
    Help converting OSC SQL code to Zencart
    There have been a number of requests to migrate the Australian FASTWAY Shipping module from OSC MS2 to Zencart, and this is what I am attempting to do. Unfortunately I am stuck on one section.
    If someone could help convert the following OSC MS2 MYSQL code to Zencart compliant MYSQL code, I'm certain the module will work.
    $sql = "SELECT * FROM fastway_zones WHERE $topcode >= f_postcode and $topcode <= f_postcode";
    $qResult = tep_db_query($sql);
    $rec = tep_db_fetch_array($qResult);
    Jul 2007
    Default Re: Help converting OSC SQL code to Zencart
    Quote Originally Posted by ozetrade View Post
    I have the same problem like this, can anyone help me?
    Jul 2007
    Thank you for the reply, i was trying to change the query into:
    $sql "SELECT * FROM fastway_zones WHERE $topcode >= f_postcode and $topcode <= f_postcode";
    $qResult $db->Execute($sql);
    $rec $db->Execute($qResult);
    But still getting errors, could you advise me how should it be?
    What error?
    And is this correct?
    To:
    $qResult = $db->Execute($sql);
    $rec = $db->Execute($qResult);
    Jul 2007
    What error?
    To:
    I'm not so sure about this, i followed the instructions on the wiki.
    $my_var_query = tep_db_query("query stuff"); >> $my_var = $db->Execute("query stuff");
    $rec = tep_db_fetch_array($qResult); >>$rec = $db->Execute($qResult); (Not sure about this)
    What is the error that you get/see?
    Jul 2007
    I got this error:
    PHP Fatal error: Call to a member function Execute() on a non-object in C:\AppServ\www\zen\includes\modules\shipping\fastway.php on line 80
    do you have an added table for fastway_zones?
    Jul 2007
    Yes i have, here is the fastway.php that need to be fixed:
      $Id: fastway.php,v 1.0 2006/02/21
      osCommerce, Open Source E-Commerce Solutions
      http://www.oscommerce.com
      Copyright (c) 2003 osCommerce
      Released under the GNU General Public License
    class fastway {
    var
    $code$title$description$num_zones$surcharge_factor$icon$enabled;
    // class constructor
    function fastway() {
          global
    $order$db;
    $this->code 'fastway';
    $this->title MODULE_SHIPPING_FASTWAY_TEXT_TITLE;
    $this->description MODULE_SHIPPING_FASTWAY_TEXT_DESCRIPTION;
    $this->sort_order MODULE_SHIPPING_FASTWAY_SORT_ORDER;
    $this->icon '';
    $this->tax_class MODULE_SHIPPING_FASTWAY_TAX_CLASS;
          if (
    zen_get_shipping_enabled($this->code)) {
    $this->enabled = ((MODULE_SHIPPING_FASTWAY_STATUS == 'True') ? true false);
          if ( (
    $this->enabled == true) && ((int)MODULE_SHIPPING_FASTWAY_ZONE 0) ) {
    $check_flag false;
    $check $db->Execute("select zone_id from " TABLE_ZONES_TO_GEO_ZONES " where geo_zone_id = '" MODULE_SHIPPING_FASTWAY_ZONE "' and zone_country_id = '" $order->delivery['country']['id'] . "' order by zone_id");
          while (!
    $check->EOF) {
            if (
    $check->fields['zone_id'] < 1) {
    $check_flag true;
             } elseif (
    $check->fields['zone_id'] == $order->delivery['zone_id']) {
    $check_flag true;
    $check->MoveNext();
          if (
    $check_flag == false) {
    $this->enabled false;
    // Customize this setting for the number of zones needed (no change required by default)
    $this->num_zones 6;
    //More options can be added later for Express, Overnight etc when someone codes it.
    $this->types = array('Fast Off-Peak' => 'std');
    // Change this surcharge factor to increase your profit margin on freight
    $this->surcharge_factor MODULE_SHIPPING_FASTWAY_SURCHARGE;
    // class methods
    function quote($method '') {
    global
    $order$cart$shipping_weight$shipping_num_boxes,  $total_weight;
    // First get the dest zip and check the db for our dest zone
    $topcode $order->delivery['postcode'];
    if (
    $topcode == '' ){
    // Something is wrong, we didn't find any zone
    $this->quotes['error'] = MODULE_SHIPPING_FASTWAY_NO_POSTCODE_FOUND;
    return
    $this->quotes;
        if (
    $rec['f_delivery'] = 'S/D') {
    $days 'same';
        if (
    $rec['f_delivery'] = 'N/D') {
    $days 'next';
        } else {
    $days $rec['f_delivery'];
    if (
    $rec['f_zone'] == '1') {
    $shipping = -1;
    $dest_zone 1;
    $zones_cost constant('MODULE_SHIPPING_ZONE_1_COST');
    $zones_handling constant('MODULE_SHIPPING_ZONE_1_HANDLING');
    elseif (
    $rec['f_zone'] == '2') {
    $shipping = -1;
    $dest_zone 2;
    $zones_cost constant('MODULE_SHIPPING_ZONE_2_COST');
    $zones_handling constant('MODULE_SHIPPING_ZONE_2_HANDLING');
    elseif (
    $rec['f_zone'] == '3') {
    $shipping = -1;
    $dest_zone 3;
    $zones_cost constant('MODULE_SHIPPING_ZONE_3_COST');
    $zones_handling constant('MODULE_SHIPPING_ZONE_3_HANDLING');
    elseif (
    $rec['f_zone'] == '4') {;
    $shipping = -1;
    $dest_zone 4;
    $zones_cost constant('MODULE_SHIPPING_ZONE_4_COST');
    $zones_handling constant('MODULE_SHIPPING_ZONE_4_HANDLING');
    elseif (
    $rec['f_zone'] == 'L') {
    $shipping = -1;
    $dest_zone 5;
    $zones_cost constant('MODULE_SHIPPING_ZONE_LOCAL_COST');
    $zones_handling constant('MODULE_SHIPPING_ZONE_LOCAL_HANDLING');
    elseif (
    $rec['f_zone'] == 'S/H') {
    $shipping = -1;
    $dest_zone 6;
    $zones_cost constant('MODULE_SHIPPING_ZONE_SHORT_COST');
    $zones_handling constant('MODULE_SHIPPING_ZONE_SHORT_HANDLING');
    } else {
    $this->quotes['error'] = MODULE_SHIPPING_FASTWAY_NO_ZONE_FOUND;
            return
    $this->quotes;
    $zones_table split("[:,]" $zones_cost);
    $size sizeof($zones_table);
            for (
    $i=0$i<$size$i+=2) {
              if (
    $shipping_weight <= $zones_table[$i]) {
    $shipping $zones_table[$i+1];
    $handling MODULE_SHIPPING_FASTWAY_HANDLING;
              if (
    $handling >0) {
    $handling_details " $" MODULE_SHIPPING_FASTWAY_HANDLING " " .MODULE_SHIPPING_FASTWAY_TEXT_HANDLING;
              } else {
    $handling_details "";
                  if (
    $handling  == 0) {
    $fastways_addons "";
                  } else {
    $fastways_addons " (" MODULE_SHIPPING_FASTWAY_TEXT_INCLUDE $handling_details.") ";
            if (
    $shipping == -1) {
    $shipping_cost 0;
    $shipping_method MODULE_SHIPPING_FASTWAY_UNDEFINED_RATE;
            } else {
    $shipping_cost = ($shipping $shipping_num_boxes) + MODULE_SHIPPING_FASTWAY_HANDLING $insurance;
    $shipping_method MODULE_SHIPPING_FASTWAY_TEXT_WAY" <b>"  $topcode "</b> - " $days " " MODULE_SHIPPING_FASTWAY_TEXT_SHIPPINGDAYS "<br>" .$shipping_num_boxes "&nbsp;" .MODULE_SHIPPING_FASTWAY_TEXT_BOXES  " " $total_weight MODULE_SHIPPING_FASTWAY_TEXT_UNITS $fastways_addons;
    $this->quotes = array('id' => $this->code,
    'module' => MODULE_SHIPPING_FASTWAY_TEXT_TITLE,
    'methods' => array(array('id' => $this->code,
    'title' => $shipping_method,
    'cost' => $shipping_cost)));
          if (
    $this->tax_class 0) {
    $this->quotes['tax'] = zen_get_tax_rate($this->tax_class$order->delivery['country']['id'], $order->delivery['zone_id']);
          if (
    zen_not_null($this->icon)) $this->quotes['icon'] = zen_image($this->icon$this->title);
          if (
    $error == true$this->quotes['error'] = MODULE_SHIPPING_FASTWAY_TEXT_ERROR;
          return
    $this->quotes;
    function
    check() {
     global
    $db;
    if (!isset(
    $this->_check)) {
    $check_query $db->Execute("select configuration_value from " TABLE_CONFIGURATION " where configuration_key = 'MODULE_SHIPPING_FASTWAY_STATUS'");
    $this->_check $check_query->RecordCount();
    return
    $this->_check;
    function
    install() {
     global
    $db;
    $db->Execute("insert into " TABLE_CONFIGURATION " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, set_function, date_added) VALUES ('Enable Fastway', 'MODULE_SHIPPING_FASTWAY_STATUS', 'True', 'Do you want to offer Fastway postcode/zone rate shipping?', '6', '0', 'zen_cfg_select_option(array(\'True\', \'False\'), ', now())");
    $db->Execute("insert into " TABLE_CONFIGURATION " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, date_added) values ('Insurance', 'MODULE_SHIPPING_FASTWAY_INSURANCE', '25:5.90', 'Insurance cost is based on the total cost of items. Example: 25:8.50,50:5.50,etc.. Up to $25 charge $8.50, from there to $50 charge $5.50, etc', '6', '0', now())");
    $db->Execute("insert into " TABLE_CONFIGURATION " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, date_added) VALUES ('Surcharge', 'MODULE_SHIPPING_FASTWAY_SURCHARGE', '', 'Do you want to add a surcharge on your freight quote (this can cover additional handling costs.) Enter it in the format of 1.1 for 10% 1.2 for 20% etc', '6', '0', now())");
    $db->Execute("insert into " TABLE_CONFIGURATION " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, date_added) VALUES ('Dispatch Postcode', 'MODULE_SHIPPING_FASTWAY_SPCODE', '2000', 'Dispatch Postcode?', '6', '0', now())");
    $db->Execute("insert into " TABLE_CONFIGURATION " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, date_added) values ('Handling Fee', 'MODULE_SHIPPING_FASTWAY_HANDLING', '10', 'Handling Fee for this shipping method (Flat rate $ value)', '6', '0', now())");
    $db->Execute("insert into " TABLE_CONFIGURATION " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, use_function, set_function, date_added) values ('Shipping Zone', 'MODULE_SHIPPING_FASTWAY_ZONE', '0', 'If a zone is selected, only enable this shipping method for that zone.', '6', '0', 'zen_get_zone_class_title', 'zen_cfg_pull_down_zone_classes(', now())");
    $db->Execute("insert into " TABLE_CONFIGURATION " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, use_function, set_function, date_added) values ('Tax Class', 'MODULE_SHIPPING_FASTWAY_TAX_CLASS', '0', 'Use the following tax class on the shipping fee.', '6', '0', 'zen_get_tax_class_title', 'zen_cfg_pull_down_tax_classes(', now())");
    $db->Execute("insert into " TABLE_CONFIGURATION " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, date_added) values ('Sort order of display.', 'MODULE_SHIPPING_FASTWAY_SORT_ORDER', '0', 'Sort order of display. Lowest is displayed first.', '6', '0', now())");
    $db->Execute("insert into " TABLE_CONFIGURATION " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, date_added) values ('Local Zone Shipping Table', 'MODULE_SHIPPING_ZONE_LOCAL_COST', '3:8.50,7:10.50,99:20.00', 'Shipping rates to Local Zone destinations based on a group of maximum order weights. Example: 3:8.50,7:10.50,... Weights less than or equal to 3 would cost 8.50 for Local Zone destinations.', '6', '0', now())");
    $db->Execute("insert into " TABLE_CONFIGURATION " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, date_added) values ('Local Zone Handling Fee', 'MODULE_SHIPPING_ZONE_LOCAL_HANDLING', '0', 'Handling Fee for this shipping zone', '6', '0', now())");
    $db->Execute("insert into " TABLE_CONFIGURATION " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, date_added) values ('Short Haul Shipping Table', 'MODULE_SHIPPING_ZONE_SHORT_COST', '3:8.50,7:10.50,99:20.00', 'Shipping rates to Short Haul Zone destinations based on a group of maximum order weights. Example: 3:8.50,7:10.50,... Weights less than or equal to 3 would cost 8.50 for Short Haul Zone destinations.', '6', '0', now())");
    $db->Execute("insert into " TABLE_CONFIGURATION " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, date_added) values ('Short Haul Handling Fee', 'MODULE_SHIPPING_ZONE_SHORT_HANDLING', '0', 'Handling Fee for this shipping zone', '6', '0', now())");
    $db->Execute("insert into " TABLE_CONFIGURATION " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, date_added) values ('Zone 1 Shipping Table', 'MODULE_SHIPPING_ZONE_1_COST', '3:8.50,7:10.50,99:20.00', 'Shipping rates to Zone 1 destinations based on a group of maximum order weights. Example: 3:8.50,7:10.50,... Weights less than or equal to 3 would cost 8.50 for Zone 1 destinations.', '6', '0', now())");
    $db->Execute("insert into " TABLE_CONFIGURATION " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, date_added) values ('Zone 1 Handling Fee', 'MODULE_SHIPPING_ZONE_1_HANDLING', '0', 'Handling Fee for this shipping zone', '6', '0', now())");
    $db->Execute("insert into " TABLE_CONFIGURATION " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, date_added) values ('Zone 2 Shipping Table', 'MODULE_SHIPPING_ZONE_2_COST', '3:8.50,7:10.50,99:20.00', 'Shipping rates to Zone 2 destinations based on a group of maximum order weights. Example: 3:8.50,7:10.50,... Weights less than or equal to 3 would cost 8.50 for Zone 2 destinations.', '6', '0', now())");
    $db->Execute("insert into " TABLE_CONFIGURATION " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, date_added) values ('Zone 2 Handling Fee', 'MODULE_SHIPPING_ZONE_2_HANDLING', '0', 'Handling Fee for this shipping zone', '6', '0', now())");
    $db->Execute("insert into " TABLE_CONFIGURATION " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, date_added) values ('Zone 3 Shipping Table', 'MODULE_SHIPPING_ZONE_3_COST', '3:8.50,7:10.50,99:20.00', 'Shipping rates to Zone 3 destinations based on a group of maximum order weights. Example: 3:8.50,7:10.50,... Weights less than or equal to 3 would cost 8.50 for Zone 3 destinations.', '6', '0', now())");
    $db->Execute("insert into " TABLE_CONFIGURATION " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, date_added) values ('Zone 3 Handling Fee', 'MODULE_SHIPPING_ZONE_3_HANDLING', '0', 'Handling Fee for this shipping zone', '6', '0', now())");
    $db->Execute("insert into " TABLE_CONFIGURATION " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, date_added) values ('Zone 4 Shipping Table', 'MODULE_SHIPPING_ZONE_4_COST', '3:8.50,7:10.50,99:20.00', 'Shipping rates to Zone 4 destinations based on a group of maximum order weights. Example: 3:8.50,7:10.50,... Weights less than or equal to 3 would cost 8.50 for Zone 4 destinations.', '6', '0', now())");
    $db->Execute("insert into " TABLE_CONFIGURATION " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, date_added) values ('Zone 4 Handling Fee', 'MODULE_SHIPPING_ZONE_4_HANDLING', '0', 'Handling Fee for this shipping zone', '6', '0', now())");
        function
    remove() {
           global
    $db;
    $db->Execute("delete from " TABLE_CONFIGURATION " where configuration_key in ('" implode("', '"$this->keys()) . "')");
        function
    keys() {
          return array(
    'MODULE_SHIPPING_FASTWAY_STATUS''MODULE_SHIPPING_FASTWAY_INSURANCE''MODULE_SHIPPING_FASTWAY_SURCHARGE''MODULE_SHIPPING_FASTWAY_MAX_SHIPWEIGHT''MODULE_SHIPPING_FASTWAY_SPCODE''MODULE_SHIPPING_FASTWAY_HANDLING''MODULE_SHIPPING_FASTWAY_ZONE''MODULE_SHIPPING_FASTWAY_TAX_CLASS''MODULE_SHIPPING_FASTWAY_SORT_ORDER''MODULE_SHIPPING_ZONE_LOCAL_COST''MODULE_SHIPPING_ZONE_LOCAL_HANDLING''MODULE_SHIPPING_ZONE_SHORT_COST''MODULE_SHIPPING_ZONE_SHORT_HANDLING''MODULE_SHIPPING_ZONE_1_COST''MODULE_SHIPPING_ZONE_1_HANDLING''MODULE_SHIPPING_ZONE_2_COST''MODULE_SHIPPING_ZONE_2_HANDLING''MODULE_SHIPPING_ZONE_3_COST''MODULE_SHIPPING_ZONE_3_HANDLING''MODULE_SHIPPING_ZONE_4_COST''MODULE_SHIPPING_ZONE_4_HANDLING');
  1. v151 Old OSC db Backup Need help converting
    By jbginz in forum General Questions
    Last Post: 26 Aug 2013, 08:46 PM
  2. v150 Converting osc contribution Post code Validation
    By vkd1980 in forum Contribution-Writing Guidelines
    Last Post: 25 Aug 2012, 05:59 AM
  3. Few lines code translation from osc to zencart - please help
    By Backstage in forum All Other Contributions/Addons
    Last Post: 14 Jul 2009, 08:49 AM
  4. Converting Header from OSC to Zen
    By msmith1111 in forum Templates, Stylesheets, Page Layout
    Last Post: 15 Nov 2008, 04:49 AM
  5. Converting from osC to Zen
    By Therose in forum All Other Contributions/Addons
    Last Post: 14 Jan 2008, 02:51 AM
