Results 1 to 10 of 16
    Nov 2005
    Default Shared SSL configuration Problem
    I have tried to find my exact problem and answer here but haven't found it yet.
    I have a shared ssl certificate throught secured.com from webmasters.com
    My site is uploaded to both webmasters and secured.com
    configure.php files were changed and ssl enabled.
    Here is what happens:
    You can checkout completely and finalize your purchase just fine. It is loading the pages from secured.com during checkout (you can see the pages being loaded in the address bar)
    My problem is that the browser doesn't think the pages are encrypted.
    Even though it is loading the page https://secured.com/~i474l/zencart....
    and all the pages are working properly the browser doesn't think it is encrypted.
    Same problem in firefox and IE
    What am I doing wrong??
    THanks
    Mar 2004
    Default Re: Shared SSL configuration Problem
    I am getting page not found
    Nov 2005
    that is not the actual link. I was just making a point.
    the website is www.fashions4fetish.com
    you can put an item in your cart and start to checkout and you will see that it loads the secured.com pages during checkout but doesn't show as encrypted in the browser.
    Mar 2004
    your redirect in htaccess is killing it,
    you need to either get rid of the re-direct.
    or move your sites up to the root
    Nov 2005
    One more thing I noticed. I don't know if this changes anything but
    if you right click the checkout button and open it in a new browser window (or tab) it now does show up as secure. Only when it opens in the same frame does it NOT show up as secure. Is that just the .htaccess file or is there something else I can do to get it to work properly?
    My web host says that zencart isn't set up to use shared ssl and I should upgrade to my own certificate, which I will if that is the only option to fix this.
    Mar 2004
    you can see for yourself that zen cart works just fine in a shared SSL
    https://www.camelot-hosting3.com/
    This is a demo site and its setup to use a shared SSL and it works properly,
    they just want to sell you a cert.
    Nov 2005
    The website you show here gives you a warning message that there is a problem with the sites security certificate that the end user must decide whether to continue or not.
    My host has a free ssl I can use that brings up this same warning message. I am paying for a ssl cert through secured.com so this doesn't happen, and the interesting thing like I said in my last note is that if you right click the checkout button after adding things to your cart and open the link in a new window or tab (firefox) then the ssl secure site works perfect in the browser.
    There must be something I'm missing that I can change to get this working right.
    Mar 2004
    the camelot-hosting3.com site shouldnt throw up a warning,
    what browser,
    this shared SSL has been tested in IE Firefox and Opera and is in use on multiple sites
    and it is a comodo cert, NOT a self signed
    there was a non secure banner image at the bottom,
    that is a true error not a cert error.
    that has been fixed,
    I oopsed when I put it in there.
    but there is no pop up now
    Nov 2005
    I normally use firefox and I received the message. I accepted the certificate so when I tried the link later it went to it no problem without the warning, so I tried it in IE (IE 7.0 beta 3) and I got this message:
    There is a problem with this website's security certificate.
    The security certificate presented by this website was issued for a different website's address.
    Security certificate problems may indicate an attempt to fool you or intercept any data you send to the server.
    We recommend that you close this webpage and do not continue to this website.
    Click here to close this webpage.
    Continue to this website (not recommended).
    More information
    Mar 2004
    OK as I explained there was a non secure image there being pulled from a third party source, that is why the error was there, it is no longer there,
    I removed the offending banner
  1. Shared SSL Problem
    By alwoodman in forum Built-in Shipping and Payment Modules
    Last Post: 7 Aug 2007, 01:14 AM
  2. shared ssl problem
    By clr in forum General Questions
    Last Post: 30 Jun 2007, 11:48 AM
  3. Shared SSL configuration not working
    By Scirrocco in forum Templates, Stylesheets, Page Layout
    Last Post: 21 Jul 2006, 04:15 PM
