    Aug 2006
    Default Easy Populate, without v_products_model field?
    Hi I am trying to make EP work for my needs. My biggest problem atm is it won't work unless you put something in the v_products_model field. I am building a comic book e-store, and comic books do not have model numbers. I tried putting a simple generic value in there (all the same), but that does not work. It assumes you are updating ONE product.
    Is there a way to disable v_products_model?
    Default Re: Easy Populate, without v_products_model field?
    No. You can't skip the "model" field.
    You can put something in the field, but it must be unique for each product.
    Surely you have something that's unique for each book ... perhaps an ISBN? Maybe a title+issue? etc
    You can turn it off from display on your site if you don't want people to see it. But you must have it in order to use easypopulate.
    Aug 2006
    Thanks for the response, this is a possible solution I was considering. The only thing is, how do I turn off displaying model number in the product page? Thanks again.
    Quote Originally Posted by redrumloa
    Admin->Catalog->Product Types->Edit Layout->.... and change the setting there that talks about product model
  1. v150 Easy Populate 4 vs. Easy Populate CSV - What's going on with so many Easy Populates?
    By oleancomputers in forum All Other Contributions/Addons
    Last Post: 20 Jun 2013, 05:58 PM
  2. Easy Populate,not v_products_model field is the primary key
    By eman1216 in forum Setting Up Categories, Products, Attributes
    Last Post: 24 Sep 2012, 07:26 PM
  3. Easy Populate Custom Field Help
    By wonderbread101 in forum All Other Contributions/Addons
    Last Post: 12 Feb 2012, 03:22 PM
  4. Easy Populate Upload Model Field Issue
    By CRYSTALDOLL in forum All Other Contributions/Addons
    Last Post: 23 Aug 2009, 09:51 AM
