Results 1 to 9 of 9
    Jun 2006
    Default fresh installation problem
    I'm on a new server now and am doing a fresh install and everything completes. However, when I try to go to the index page it comes up with this error:
    1146 Table 'tablename.TABLE_SESSIONS' doesn't exist
    in:
    [select value from TABLE_SESSIONS where sesskey = 'f273e79ce27444aa4b7ae4c748fba63e' and expiry > '1155677027']
    Also, when I go to the admin page I get this error and all the formatting is not present after I login the admin area. (The zencart logo appears, but the navigation bar is gone and the coloring)
    # $Id: .htaccess 2996 2006-02-09 00:42:17Z drbyte $ # # This is used with Apache WebServers # The following blocks direct HTTP requests in this directory recursively # # This does not affect PHP include/require functions # # Example: direct access to http://server/admin/includes/application_top.php will not work with the following installed Order Deny,Allow Deny from all Allow from localhost
    Can anyone help?
    Feb 2006
    Chicago
    Default Re: fresh installation problem
    That means TABLE_SESSIONS was not created and possibly any tables after that
    Please check in the phpmyadmin that number of tables for zen cart should be 93.
    If there are any less, you need to create them seperately
    I would recommend doing a fresh install
    Tutorials on Zen Cart
    http://tutorials.zen-cart.com/index.php
    advanced.programmer at gmail dot com
    In love with Zen Cart!!
    Jun 2006
    just checked that there are 93 and sessions is also present. not sure what the problem could be, i also ran the install again... any other suggestions?
    Feb 2006
    Chicago
    Just see if what 'tablename.TABLE_SESSIONS points to
    Jun 2006
    ok. i was able to fix everything, by reloading all the files and reinstalling. i've been having major problems with file uploads...
    Feb 2006
    Chicago
    Glad to hear the updates
    Nov 2004
    Norfolk, United Kingdom
    Maybe the FTP programme you're using?
    Use a reliable one like FileZilla or WS FTP. Don't use Cute, Smart or Dreamweaver to FTP files.
    Vger
    Quote Originally Posted by etoile03
    Jun 2006
    yea..i'm using filezilla already. i switched from wireless to lan, and uploading problems are gone..i think
    Nov 2004
    Good news!
    Vger
  1. fresh installation 1.3.8a vs 1.3.9h
    By jaca in forum General Questions
    Last Post: 11 May 2011, 11:08 AM
  2. Fresh installation - fatal error
    By shakur96 in forum Installing on a Windows Server
    Last Post: 25 Mar 2009, 03:17 PM
  3. Problem after fresh installation ion IIS6
    By thommy in forum Installing on a Windows Server
    Last Post: 6 Jun 2006, 11:08 PM
