Thread: Body Outline
    Jan 2005
    Default Body Outline
    Hello y'all:
    I have been changing the CSS to give my client a store that looks more like their current website, but I cannot for the life of me, find where the thin border around the body of the page is located in any of the CSS's. Anyone know where I can find that and change it?
    Your help is GREATLY appreciated!
    Aug 2006
    Canada
    Default Re: Body Outline
    Do you have a URL? Or check on the declarations for #mainWrapper.
    Jan 2005
    Yes, I have a URL: http://63.134.228.236/zencart/index.php?main_page=index
    You'll note the large red outline on the footer and the header. I need it to go around the center section (which I call the body section).
    Also, the #mainwrapper doesn't seem to be it, but I could be wrong.
    Thank you so much for the help!
    Yoy are using the combination classic template with 2 stylesheets...
    Please look in the downloads section for a suitable 1.3.x template...Follow the install instructions and be happier from then on.
    Nov 2005
    Colorado Springs, CO USA
    In your stylesheet_original.css check TABLE.headerNavigation
    and TABLE.footer
    The border definitions are set at 5px.
    make the changes your need.
    Jan 2005
    Well, I finally figured it out (in case anyone needs it for future reference), it's in the stylesheet_new.css and it's #navColumnOne & #navColumnTwo.
  1. Replies: 8
    Last Post: 28 Feb 2012, 03:05 PM
  2. Outline around buttons
    By mzunderstood in forum Basic Configuration
    Last Post: 13 Nov 2010, 11:25 PM
  3. Help With Attributes Outline
    By Kenichi in forum Templates, Stylesheets, Page Layout
    Last Post: 18 Jul 2010, 07:46 AM
  4. side boxes outline ???
    By symmo in forum Templates, Stylesheets, Page Layout
    Last Post: 11 Jun 2007, 07:48 PM
  5. Static body for resizing (How to keep the body from sliding and moving when resizing)
    By bjmhistory in forum Templates, Stylesheets, Page Layout
    Last Post: 26 Jan 2007, 12:28 AM
