Results 11 to 20 of 21
    Feb 2006
    Default Re: Help: Backup mysql problem
    thank you for the time and info.
    I have a ticket into them with this info , I think I have a basic idea of what might be happening. they insist I should use the path
    /usr/bib/mysqldump
    I'll see what they say,
    Mach
    If you learn by making mistakes, then I'm learning a hell of a lot.
    Http://octagonwebworks.com
    lol ... they're right ... you "should" use that path.
    It would seem that the command-line environment they're offering you doesn't allow that.
    However, try this for kicks...
    1. open the backup_mysql screen
    2. click on Backup
    3. edit the URL and add this to the end of it:
    &debug=ON
    ...and press Enter
    4. now click the backup button on the sidebox
    Post the debug info from the top of the screen here.... without your passwords of course.
    Feb 2006
    Checking Path: /usr/bin/
    COMMAND FILES SELECTED:
    mysqlexe="/usr/bin/mysql"
    mysqldumpexe="/usr/bin/mysqldump"
    COMMAND: "/usr/bin/mysqldump" "--host=localhost" "--user=xuserx" "--password=xpwdx" --opt --complete-insert "--result-file=/home/xxx/public_html/adminxxxxx/backups/db_xdbx-20060904201447.sql" xdbx 2>&1
    Result code: 127
    valueA:
    valueB:
    ERROR: Could not locate the MYSQLDUMP backup utility. BACKUP FAILED.
    Mach
    Okay ... the tool is attempting to run the binary from the prescribed location, but the PHP security settings for chroot are preventing it from happening as required.
    It's all up to your host now ...
    Feb 2006
    Quote Originally Posted by DrByte
    Thank you very much! Now I know what to show them and tell them.
    Mach
    Feb 2006
    maybe they are working on it, because now I get this:
    PHP-Disabled-functions: ini_alter,system,passthru,shell_exec,leak,listen,chgrp,apache_setenv,define_sysl og_variables,openlog,syslog,ftp_exec
    Mach
  7. #17
    If that message is being displayed by the backup_mysql, note that sometimes it's a misnomer ... there's a tiny error in the logic that displays the message, in that it doesn't always detect only what it's supposed to.
    You're only concerned if "exec" is disabled. "shell_exec" is not used by this script, so is not a problem. Thus, if "exec" itself is not listed, you should be able to run it (assuming the host has fixed everything else properly too)
  8. #18
    Feb 2006
    well, they haven't fixed anything yet. they say they need a way to execute the scripts to produce the error on their end. I am relunctant to give them an admin user name and password, but maybe I should. It's not that I don't trust them.....but my customers details are in there.
    Mach
  9. #19
    you could set up a demo site for them, with the backup addon installed ...
  10. #20
    Feb 2006
    Dr. Byte,
    I can't thank you enough! Because of you I sounded like I almost knew what i was talking about and they didn't just blame it on a third party script and looked into it and fixed it.
    Thank you. They haven't told me what the problem was though, I asked, and I bet they installed the exec_dir patch on php to chroot requests to binaries and didn't have the permissions set right, like you said.
    Thats what i told them i thought the problem was anyway.
    Thanks a bunch!
    Mach
  1. Backup MySQL mod v1.4 - problem
    By Earnest-Enterprises in forum All Other Contributions/Addons
    Last Post: 22 Nov 2010, 01:45 AM
  2. Database Backup Manager - MySQL: problem
    By pixelwrangler in forum All Other Contributions/Addons
    Last Post: 24 Nov 2009, 10:25 PM
  3. Backup MySQL Plug-in - install problem
    Last Post: 4 May 2009, 07:07 PM
  4. Backup MySQL mod - Windows 2003 problem
    By metafizx in forum All Other Contributions/Addons
    Last Post: 2 Jul 2007, 07:29 AM
