Results 1 to 10 of 11
    Sep 2006
    Default Store will not load after installation
    I just installed 1.3.5 Admin comes up ok. But the store only comes up
    blank any suggestions
    Axel
    N of San Antonio TX
    Default Re: Store will not load after installation
    Axel,
    If you're still having a problem, try checking the two configure.php files located in admin/includes/ and includes/. I bet you'll find a bad directory call in one of them.
    A little help with colors.
    You might also try looking at your server's errorlog for details of what's wrong.
    Jun 2006
    Koh Samui
    I had the same problem, a blank page, and it was because of a change in the name of the phpBB file which was changed to phpbb (no more caps).
    Your php errorlog file should be checked for the exact error.
    Ronald.
    [FONT="Verdana"]http://www.xlventures.eu[/FONT]
    Sep 2006
    Hi everybody I changed the phpbb and I still have the same problem
    my error code is
    PHP Fatal error: Cannot instantiate non-existent class: phpbb in /hermes/web06/xxxxxx/xx.xxxxxxxx/catalog/includes/autoload_func.php on line 79
    Axel
    Jun 2006
    Koh Samui
    Can you check if you have a <STORE>/includes/classes/class.phpbb.php file?
    Ronald.
  1. changed server and store will not load
    By david52 in forum General Questions
    Last Post: 8 Sep 2010, 05:57 AM
  2. Did not load after sucessful installation on LAMP_Ubuntu
    By aimw in forum Installing on a Linux/Unix Server
    Last Post: 11 Apr 2010, 10:44 PM
  3. CAPTCHA Image will not load after moving to another server - anyone know why??
    By touchclothing in forum All Other Contributions/Addons
    Last Post: 25 Dec 2008, 05:03 AM
  4. After installation admin page will not open properly
    By orphee in forum Installing on a Linux/Unix Server
    Last Post: 7 Mar 2008, 09:34 AM
  5. Can't Load Admin Page After Installation
    By pod in forum Basic Configuration
    Last Post: 17 Aug 2006, 02:48 PM
