Page 22 of 24 FirstFirst ... 122021222324 LastLast
Results 211 to 220 of 235
  1. #211
    Nov 2008
    Slovenija
    Default Re: Problem with Flash Header
    width 468, height 60
    The flash movie should be in that location because I need that, each time you change the language, the banner change to configure the selected language.
    As I understand I need to put that code in the source:
    /public_html/basicinstinctlingerie/includes/templates/1228/buttons/<?php echo $_SESSION['language']; ?>/slogan.swf"
    For the swfobject.js i can move it. Please, thell me where.
    I would like to put the flash in tpl_header.php at the slogan div.
    I dont' know how to write the source.... with http:www, just basicinstinctlingerie/includes.....
    I really appreciate your help!
    I love internet and the power of information... Best Wishes!!
  2. #212
    Oct 2007
    Kentucky - USA
    I am unaware of language issues. I have never put the swf in tpl_header.php but if you know you need to put it here then so be it. I believe the code you need to use is as follows:
    <!--top of flash display-->
    script type="text/javascript" src="basicinstinctlingerie/swfobject.js"></script>
        <script type="text/javascript">
        if (swfobject.hasFlashPlayerVersion("6.0.0")) {
          var fn = function() {
            var att = { data:"includes/templates/1228/buttons/slovensko/slogan.swf", width:"468", height:"60"};
            var par = { flashvars:"foo=bar" };
            var id = "replaceMe";
            var myObject = swfobject.createSWF(att, par, id);
          swfobject.addDomLoadEvent(fn);
        </script>
        <div id="replaceMe">Alternative content</div>
    <!--bottom of flash display-->
    Good luck
    Sawhorse
  3. #213
    Nov 2008
    Slovenija
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
    html xmlns="http://www.w3.org/1999/xhtml" lang="en" xml:lang="en">
    head>
    title></title>
    meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
    script type="text/javascript" src="swfobject.js"></script>
                var flashvars = {};
                var params = {};
                var attributes = {};
                swfobject.embedSWF("slogan.swf", "flash player required", "468", "60", "6.0.0", "expressInstall.swf", flashvars, params, attributes);
            </script>
        </head>
        <body>
            <div id="flash player required">
                <a href="http://www.adobe.com/go/getflashplayer">
                    <img src="http://www.adobe.com/images/shared/download_buttons/get_flash_player.gif" alt="Get Adobe Flash player" />
                </a>
        </body>
    </html>
    Now the flash is working in explorer, but in firefox i have the: "get the adobe flash player". ( I have version 10.0.......
  4. #214
    Nov 2008
    Slovenija
    I find a great tutorial here, but maybe I missed something.
    http://www.gotoandlearn.com/play?id=77
    This tutorial should help a lot of users. I hope.
  5. #215
    Oct 2007
    Kentucky - USA
    Check to see if you have loaded in your FF the plugin for adobe flash player.
    Sawhrose
  6. #216
    Nov 2008
    Slovenija
    Yes, shockwave flash is enabled.
    With the old code without swfobject.js it' worked.
  7. #217
    Nov 2008
    Slovenija
    My entire code looks like this. Is in tpl_header.php
    It works for all the browser exept firefox.
    What is intresting is that when I put the code with "firebug" wich inspect element on the page and show you the changes without save it, it works.
    When I edit the tpl_header work's only in other browser. In F F i have the gif picture to get flash player.
    <div id="slogan">
    head>
    title></title>
                var flashvars = {};
                var params = {};
                swfobject.embedSWF("slogan.swf", "flash player required", "468", "60", "6.0.0.0", "expressInstall.swf", flashvars, params, attributes);
            </script>
        </head>
        <body>
                </a>
        </body>
    </html>
  8. #218
    Oct 2007
    Kentucky - USA
    I get the same thing you do.
    Check your php code. The one you show is not the same as the one I gave you.
    Sawhorse
  9. #219
    Nov 2008
    Slovenija
    Your code work's only in I.E. In F F i have alternative content.
    I create the code with the swfobject generator. It' work's, but in F F i have the get the flash player.
    So i don't know what to do anymore....
    Thank you for your help!
  10. #220
    Oct 2007
    Kentucky - USA
    It is as if swfobject.js can't be found. Where is it currently located?
    Sawhorse
  1. v150 Problem with flash header size
    By GodfatherAntiques in forum Templates, Stylesheets, Page Layout
    Last Post: 21 Mar 2012, 10:12 AM
  2. Problem with flash on main page (not header)
    By sartor in forum General Questions
    Last Post: 14 Jan 2009, 10:59 AM
  3. Once again problem with Flash header
    By craigpowell in forum Templates, Stylesheets, Page Layout
    Last Post: 22 Sep 2008, 01:42 AM
  4. Problem with Flash Header pt2
    By hondauser85 in forum Templates, Stylesheets, Page Layout
    Last Post: 6 Jun 2007, 04:03 PM
  5. help with flash header
    By wizzard in forum Templates, Stylesheets, Page Layout
    Last Post: 1 Jun 2007, 05:58 PM
