Results 1 to 7 of 7
    Jan 2006
    Australia
    Multiple customers using same session id! Need Help
    Hi all
    Wondering if someone could help decipher this problem that I have just encountered
    Paypal have been testing my store as requested by myself due to problems with receiving IPN notifications back to my admin.
    While testing the store, they created an account and proceeded to place an item in the shopping cart and then proceeded to checkout upto step 3 (order confirmation) (NO PROBLEM YET TILL I LOOK IN USER TRACKING)
    When I checked user tracking, I discovered that the tech guy from Paypal somehow during account creation managed to place items in cart under another customers session id even after that customer had logged off from their session.
    So instead of the tech guy whom I will refer to as Mr X showing up as Mr X as being logged in it was as though my customer whom I will refer to as Ms Y continued to shop under her name. Tracking shows that this session has been open for over 57 hours.
    Come to think it, Of late I have noticed quite a few sessions for guests running into the hundreds of hours without closing. I would say that these sessions contain tracking for possibly several guests. I AM SURE THAT THS IS A PROBLEM
    In regard to Bots/spiders there sessions can run into something like 2000 + hours. I am not sure if this is normal.
    Below is my configuration for sessions
    Title Value Action
    Session Directory /home/heavenly/public_html/catalogue/cache
    Cookie Domain True
    Force Cookie Use False
    Check SSL Session ID False
    Check User Agent False
    Check IP Address False
    Prevent Spider Sessions True
    Recreate Session False
    IP to Host Conversion Status true
    Please note that I take particular care NOT to leave any session id's in the link url when creating links
    Any help would be really appreciated!!
    Jun 2003
    Default Re: Multiple customers using same session id! Need Help
    What version are you using?
    Jan 2006
    Australia
    Thanks for your response Kim
    Live site is running 1.3.02 but I am in the process of upgrading to 1.3.5., fine tuning it at the moment.
    Issue happened in my live site (1.3.02)
    Jun 2003
    Try turning on the recreate sessions.
    Jan 2006
    Australia
    Thanks kim.
    Done as you suggested.
    Is there anyway that I can ensure that this was effective, or do i need to wait a while to see if it happens again?
    Jun 2003
    Keep an eye on it for the moment and test your login and checkout to make sure things are functioning properly.
    Jan 2006
    Australia
    Thanks Kim
    Shall do!!
  1. Same invoice No. for all customers - using NAB
    By Edm in forum Addon Payment Modules
    Last Post: 5 Jun 2008, 10:50 AM
  2. ZenID and Customers using the same basket
    By perfecthill in forum General Questions
    Last Post: 17 May 2007, 08:41 PM
  3. Using the same shop on multiple domains
    By michaelhl in forum General Questions
    Last Post: 15 Mar 2007, 06:46 PM
  4. Question on multiple storefronts using same database
    By rizzy in forum General Questions
    Last Post: 13 Dec 2006, 10:51 PM
