Results 1 to 2 of 2
    Apr 2006
    /index.php not comes: some configure file problem
    hy friends this is my website:
    http://caytech.net/index.php
    now when you click on any Today's Special product on main webpage it saws wrong link:
    see .netindex.php comes together right now.
    http://www.caytech.netindex.php/?main_page=------
    it should be
    http://www.caytech.net/index.php?main_page=-----
    i saw you my configure file.
    you can see my php info file at
    ww.caytech.net/phpinfo.php
    define('HTTP_SERVER', 'http://www.caytech.net');
    define('HTTPS_SERVER', 'https://www.caytech.net');
    define('DIR_WS_CATALOG', '');
    define('DIR_WS_HTTPS_CATALOG', '');
    define('DIR_WS_PHPBB', '/');
    define('DIR_FS_CATALOG', '//usr/local/apache2/misc/23/699/532/568/user/web/caytech.net/');
    define('DB_TYPE', 'mysql');
    define('DB_PREFIX', '');
    define('DB_SERVER', 'sql7.bravehost.com');
    define('DB_SERVER_USERNAME', 'xxxxxxx');
    define('DB_SERVER_PASSWORD', xxxxxxxx');
    define('DB_DATABASE', 'xxxxxxx');
    define('STORE_SESSIONS', 'db'); // use 'db' for best support, or '' for file-based storage
    define('DIR_FS_SQL_CACHE', '/usr/local/apache2/misc/23/699/532/568/user/web/caytech.net/cache');
    can you help me ...its very urgent for me
    vr4indian######################
    vishal.comp######################
    i solved last problem : it was DB error
    Mar 2004
    Default Re: /index.php not comes: some configure file problem
    you need to change these
    to this
    please only one post per topic,
  1. Replies: 3
    Last Post: 2 Jul 2009, 07:28 PM
  2. Replies: 2
    Last Post: 1 Jul 2007, 05:10 AM
  3. /index.php does not comes
    By vr4indian in forum Installing on a Windows Server
    Last Post: 30 Oct 2006, 03:04 PM
  4. Replies: 3
    Last Post: 4 Sep 2006, 11:01 AM
