forgot the config and check if you have this chapter and files in
.includes/templates/
the zen configuration look fine i think you have a problem with your server configuration maybe you need to ask to your hosting.
Have you look in your error log to find out what is wrong
You've obviously uninstalled the whole shop now, but this is what you need to do:
In the includes folder edit the .htaccess file from:
<Files *.php>
Order Deny,Allow
Deny from all
</Files>
to:
<Files "*.php">
Order Deny,Allow
Deny from all
</Files>
If that doesn't work then delete the .htaccess file in the includes folder.
Vger
¿ .htaccess control tha acces to the pages ?
May I used this to block mi admin module ? or with the login is enought ?
That file is only intended to block access to .php pages from outside of your website itself - to stop people directly accessing php pages in those folders. Unfortunately it also sometimes blocks access to all language level buttons and icons as well.
Vger
