Results 1 to 3 of 3
    Oct 2006
    Default left column width and center content problem
    I've started some layout changes.
    First I switched off everything in the right column and made its width 0px from the admin side.
    so I only have a left column and center content.
    I need the left column to be about 190px to accomodate my menu.
    The center content appears to be making it not touch the top of the horizontal menu bar.
    Should I remove the table completely and just use divs?
    Should I style the left colomn width using my custom stylesheet and ignore the width in the admin side?
    That way if I do upgrade then the custom stylesheet will alwas control the width
    see what ive done so far here
    Apr 2006
    West Salem, IL
    Default Re: left column width and center content problem
    well first off you need to change the width of the #mainWrapper to 767px to fix the problem of the main content area bumping out past the edge.
    Its this statment that is giving you the space at this top above the categories header:
    .leftBoxContainer {
    margin-top: 1.5em;
    Mike
    AEIIA - Zen Cart Certified & PCI Compliant Hosting
    Oct 2006
    thank you barco,
    that's fixed now.
    onwards and upwards. Im starting to get the hang of ZC.
    keep an eye on the site over the coming weeks
  1. Space between left layout column and right content column
    By eazy in forum Templates, Stylesheets, Page Layout
    Last Post: 21 Mar 2013, 02:16 AM
  2. Can I add Categoy links left and Right column around center column?
    By cshart in forum Templates, Stylesheets, Page Layout
    Last Post: 27 Oct 2010, 06:06 PM
  3. Problem with left column width
    By [email protected] in forum Basic Configuration
    Last Post: 5 Oct 2007, 06:44 AM
  4. center boxes in left and right column
    By chelseagirl in forum Templates, Stylesheets, Page Layout
    Last Post: 3 Sep 2006, 01:34 AM
