Re: Breadcrumb 'header' is not 100% width.. please help.
Can anyone tell me what I've done, or where I can fix this? I'd like the breadcrumb 'header' to go all the way to both sides, ABOVE the sideboxes.
The page is designed so the breadcrumb fits between the side columns. To change it you will need to create a custom template override for the common/tpl_main_page.php. See the FAQs for instructions on creating your custom templates.
