Results 1 to 7 of 7
    help question Display Multiple Products Qty Box
    I want to display the multiple products qty box instead of the buy now button. I had it set up this way before upgrading to the most recent version. I have Display Multiple Products Qty Box Status and Set Button Location under Product Listing set to 3 - as I did before. But I can't get it to display - only the buy now button. What am i missing?
    Much thanks for your time!!
    Default Re: Display Multiple Products Qty Box
    Configuration ... Product Listing ...
    Display Product Add to Cart Button (0=off; 1=on; 2=on with Qty Box per Product)
    Do you want to display the Add to Cart Button?
    NOTE: Turn OFF Display Multiple Products Qty Box Status to use Option 2 on with Qty Box per Product
    Needs to be set to 1 ...
    I don't want to display the 'add to cart' button. i have it set to 0=off.
    (Mine doesn't have an opiton 2=on with Qty Box per Product, only 0=off; 1=on.)
    With it set to 0=off, '...more info' is displayed. No matter what I set Display Multiple Products Qty Box Status to (0 ; 1 ; 2; or 3) '... more info' displays.
    What version of Zen Cart are you running?
    I'm running version 1.3.7. And I noticed another post about my same problem, but don't understand how it was resolved. (subjuct: Config > Product Listing > Missing options 1.3.6 -inksale)
    ****Display Product Add to Cart Button (0=off; 1=on; 2=on with Qty Box per Product)
    NOTE: Turn OFF Display Multiple Products Qty Box Status to use Option 2 on with Qty Box per Product****
    I don't have the option 2=on, only 0=off and 1=on.
    Idea or Suggestion Re: Display Multiple Products Qty Box
    I found this on another post:
    1.3.5 Upgrade, Display Product Add to Cart Button 2 Not Showing
    Fresh 1.3.5 installation is fine, but when upgrading from 1.3.0.2 I discovered that the new radio button for option 2=on with Qty Box per Product wasn't showing.
    mysql_upgrade_zencart_1302_to_135.sql contains this:
    UPDATE configuration SET configuration_title = 'Display Product Add to Cart Button (0=off; 1=on; 2=on with Qty Box per Product)', configuration_description = 'Do you want to display the Add to Cart Button?<br /><br /><strong>NOTE:</strong> Turn OFF Display Multiple Products Qty Box Status to use Option 2 on with Qty Box per Product' WHERE configuration_key= 'PRODUCT_LIST_PRICE_BUY_NOW';Running this seems to fix it:
    UPDATE configuration SET set_function = 'zen_cfg_select_option(array(\'0\', \'1\', \'2\'), ' WHERE configuration_key= 'PRODUCT_LIST_PRICE_BUY_NOW';
    It did the trick. Is this a bug with the new upgrade?
    Thank you imac!! And thank you Ajeh!
    This is fixed in the current v1.3.7 ...
  1. Replies: 1
    Last Post: 27 Mar 2016, 06:29 AM
  2. v139h Display Attributes, Qty Discounts & Qty Box in a Table
    By pool27 in forum Setting Up Categories, Products, Attributes
    Last Post: 28 May 2014, 11:49 AM
  3. v139h Display Multiple Products Add to Cart AND default qty 1
    By pacu in forum Templates, Stylesheets, Page Layout
    Last Post: 2 Feb 2012, 11:55 AM
  4. Display Attributes/Options, Qty Discounts & Qty Box in Matrix
    By teaj in forum Templates, Stylesheets, Page Layout
    Last Post: 21 Apr 2011, 02:59 PM
  5. Multiple Products Qty Box Shows 0 by default
    By aly22 in forum Setting Up Categories, Products, Attributes
    Last Post: 24 Apr 2009, 04:37 AM
