I assume this is a "Grid" issue.
Problem
Old cart= 1.2.6 http://www.sonofthepharaoh.com/estoreonline
This is the layout I'm after - the category images are equal on the rows.
There are two images on the bottom row, no problem, maybe I'll add another category.
New cart 1.3.7 http://www.sonofthepharaoh.com/Demo
This is my test installation
This is the broken layout. The images on the main page are ALWAYS one less than demanded by \\configuration\maximum values, and the leftover amount is placed singly in the row below - it's awful.
IE if the maximum value is 4 - the cart displays 3 categories in the row with one category alone in the next row down.
3 - the cart displays 2
2 - the cart displays 1
if the maximum value is set to 1 - the images center on the page.
I have tried searching the forums for solutions using the terms "category rows", and "Columns per row" and have tried EVERY solution suggested in EVERY thread as a result of those searches. I have resized images back and forth and then to default while changing all the other parameters to no avail. This process has taken the better part of two weeks to go through. I understand there is a "Grid" module of some sort but I'd rather not complicate matters further unless it's a bulletproof solution to this issue that won't generate three more issues that require four more settings to be changed in five more hidden settings locations. If you know what I mean.
Does anyone have any further suggestions?
