When you go to my shop page first off, it look fine, but if you refresh it or add an item the following message comes up.
Warning: Variable passed to each() is not an array or object in /home/petsandc/public_html/brondegpostoffice/includes/classes/db/mysql/query_factory.php on line 114
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/petsandc/public_html/brondegpostoffice/includes/classes/db/mysql/query_factory.php:114) in /home/petsandc/public_html/brondegpostoffice/includes/functions/sessions.php on line 108
Warning: Cannot modify header information - headers already sent by (output started at /home/petsandc/public_html/brondegpostoffice/includes/classes/db/mysql/query_factory.php:114) in /home/petsandc/public_html/brondegpostoffice/includes/init_includes/init_templates.php on line 78
at the top.
Does anyone have any idea what I would need to do to correct it?
Also if you click on an item this comes up (but I think this problem from reading other topics is due to premissions.)
Warning: include(includes/modules/FILENAME_XSELL_PRODUCTS.php) [function.include]: failed to open stream: No such file or directory in /home/petsandc/public_html/brondegpostoffice/includes/templates/template_default/templates/tpl_modules_xsell_products.php on line 17
Warning: include() [function.include]: Failed opening 'includes/modules/FILENAME_XSELL_PRODUCTS.php' for inclusion (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/petsandc/public_html/brondegpostoffice/includes/templates/template_default/templates/tpl_modules_xsell_products.php on line 17
lastly how do you change the weight from lb to kg.
thanx for your time.
Mark Kelly
NB: shop url http://brondegpostoffice.co.uk/
