Results 1 to 10 of 10
    Nov 2005
    Default A small phpBB problem (I think)
    I have just enabled the forum at my page (www.csstemplateheaven.com) Everything works fine except the forum link in the information box. If you click it you get the serverpath in the adressfield, help is appreciated
    Default Re: A small phpBB problem (I think)
    Post your entry for this that is in your configure.php file
    Nov 2005
    define('DIR_WS_PHPBB', '/home/C/csstempl/www/forum/');
    If this is located where I think it is from your post try changing it to this:
    define('DIR_WS_PHPBB', '/forum/');
    Nov 2005
    I have tried but nothing works if I do it like that
    Apr 2006
    West Salem, IL
    if you hover over the forum link in your info sidebox you see thisnote the extra /
    could you post your configure.php without user/password of course
    Mike
    AEIIA - Zen Cart Certified & PCI Compliant Hosting
    OK I just did this locally and this is the result for the configure.php entry:
      define('DIR_WS_PHPBB', 'phpbb/');
    My directory for the forum sits with the Zen Cart files in a folder named phpbb
    You have it installed with/in a folder named "forum"
    so change what I incorrectly posted earlier to:
    define('DIR_WS_PHPBB', 'forum/');
    And see if that corrects it. This is due to the heading in the configure.php file for these entries that states:
    And not as the next set of entries requires which is this:
    Which is what you are attempting with:
    Apr 2006
    West Salem, IL
    These are a couple of the lines from my config file
    define('DIR_FS_CATALOG', '/home/staband/public_html/');
    define('DIR_WS_PHPBB', '/home/staband/public_html/forum/');
    Maybe this will help......
    Mike
    Nov 2005
    Thanks for the help
    I removed the / before "forum" and it works perfect now.
    Sorry for the initial mis lead on this
  1. browser problem. i think
    By silentsigma in forum General Questions
    Last Post: 19 Jan 2010, 06:13 AM
  2. CSS Problem i think ??
    By gmrm in forum General Questions
    Last Post: 11 Jan 2010, 12:58 PM
  3. phpBB problem
    By Ripper in forum General Questions
    Last Post: 10 Oct 2007, 03:40 PM
  4. checkout_shipping problem I think
    By TheWetFish in forum Built-in Shipping and Payment Modules
    Last Post: 31 May 2006, 04:51 AM
