Results 1 to 8 of 8
    Apr 2006
    Default alignment of subcategory images - help!
    hello,
    im trying to center align my subcategory images and remove a little peice of header text.
    at the moment my page looks like this:
    http://www.e-rose.org/current.jpg
    i would like it to look like this:
    http://www.e-rose.org/ideal.jpg
    i just want to move the subcategory images over a little bit to the right so they are centered. can anyone help?
    Default Re: alignment of subcategory images - help!
    Find this in your stylesheet.css for your template and separate or if not found add it:
    #productListHeading {
            display: none;
    For the other post a url
    Apr 2006
    im a bit confused, does that bit of code help align the images? i want my subcategory images to be centered on the main page instead of off to the left.
    You asked 2 things:
    the code takes care of this.
    Apr 2006
    ok thank you :) the other thing i needed was help aligning my subcategory images.
    on this page:
    http://www.shelovesstars.com/shop/in...index&cPath=75
    the two images/catergory links 'fabric badges' & 'lavender birdies' i would like moved over a bit so that they are in the center rather than off to the left
    Same file - stylesheet.css - find & separate or add this:
    .categoryListBoxContents {
            text-align: center;
    Apr 2006
    thanks so much, that seems to have done it :) its made my product descriptions centered too : http://www.shelovesstars.com/shop/in...index&cPath=71
    could i change that back so the text is left aligned? i dont mind if its not possible now ive edited the code.
    thanks again for your help!
    Atlanta, GA
    since you want the categories centered, but the new items listings to have their text aligned left, then try adding this in addition to what you've already done:
    (don't take my word for it, I'm kinda new with the zen-cart stuff, but this is what worked in mine, when mine were all aligned left and I wanted em centered... lol... i just reversed it for your situation)
    in addition to:
            text-align: center;
    try:
    .centerBoxContentsSpecials, .centerBoxContentsFeatured, .centerBoxContentsNew  {
    text-align:left;
    also, I would change in all your templates pages: (templates>template_default(or whichever one your using) >templates) from:
     <br class="clearboth"/>
    CHANGE TO
     <div class="clearboth" />
    this will help with some funny layout in some browsers, but will not change the functionality of things. cleared up a lot of alignment issues I was having between different browsers ;)
    ~~give me feedback on my home decor store~~
    ~~sleep is a symptom of caffeine deprivation~~
    ~~COFFEE.SYS Not Found: User startup disabled.~~
    ~~ if(pot.coffee=EMPTY) {programmer->;brain=OFF}; ~~
  1. Replies: 4
    Last Post: 9 Oct 2011, 02:22 PM
  2. Making Subcategory images alignment
    By Delights in forum Templates, Stylesheets, Page Layout
    Last Post: 22 Oct 2008, 04:50 AM
  3. subcategory heading alignment problem in FF
    By abcisme in forum Templates, Stylesheets, Page Layout
    Last Post: 29 Sep 2008, 09:36 PM
  4. Subcategory Listing Page Alignment
    By TurtleDove in forum Templates, Stylesheets, Page Layout
    Last Post: 15 Jul 2006, 12:30 AM
