2 days ago I upgraded my 1.3.5 install to 1.3.7 via Fantastico. After that it complained that my DB was still at 1.3.6 so I ran the zc_install and upgraded the DB and all was fine.
Then today I decided to install Paypal Express checkout, which I did. I then decided to test it, and to my surprise I am getting the following errors above my home page.
Also on the page itself I get the following instead of my products;Warning: Variable passed to each() is not an array or object in /home/homann/public_html/store/includes/classes/db/mysql/query_factory.php on line 114
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/homann/public_html/store/includes/classes/db/mysql/query_factory.php:114) in /home/homann/public_html/store/includes/functions/sessions.php on line 108
Warning: Cannot modify header information - headers already sent by (output started at /home/homann/public_html/store/includes/classes/db/mysql/query_factory.php:114) in /home/homann/public_html/store/includes/init_includes/init_templates.php on line 78
1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'EXPECTED_PRODUCTS_SORT limit MAX_DISPLAY_UPCOMING_PRODUC' at line 7
in:
[select p.products_id, pd.products_name, products_date_available as date_expected from zen_products p, zen_products_description pd where p.products_id = pd.products_id and p.products_status = 1 and pd.language_id = '1' and p.products_date_available >=20070202 order by EXPECTED_PRODUCTS_FIELD EXPECTED_PRODUCTS_SORT limit MAX_DISPLAY_UPCOMING_PRODUCTS]
I then tried creating a test installation and pointing it to my main database to see if it was in the code. The same errors occur.
Also from the Admin side, everything is working fine
Can anybody shed some light on how to fix this please?
Cheers,
Peter.
