Results 1 to 9 of 9
    Jun 2006
    The Netherlands
    Default Disabling MasterCard doesn't work with own payment module
    We have our own payment module (created by a 3rd party) for processing creditcards, which is working fine, but now we don't want to process MasterCard transactions through that account.
    I tested it with "Credit Card Enable Status - MasterCard - Value 0" at Configuration -> Credit Cards, but this doesn't work. I still can go to the "step 3 of 3" checkout procdure without getting a error.
    Is that possible because there are some things missing in the payment module? Is there another way how we can disable MasterCard transactions?
    We are using:
    Zen Cart 1.3.0.1
    Database Patch Level: 1.3.0.1
    Jun 2006
    The Netherlands
    Default Re: Disabling MasterCard doesn't work with own payment module
    We tried to update to the latest zen-cart version, but that doesn't work. Errors at the payment.php
    Any solution to disable mastercard with this version?
    Is there any manual for creating your own payment module?
    Jun 2003
    I think you need to get with the developer that created your payment module. It sounds as if there may be hardcoded values that are causing problems.
    Jun 2006
    The Netherlands
    Quote Originally Posted by Kim View Post
    He don't work any more
    Any way I try to find some solution to put java script on page checkout_payment.php Step 2 of 3 to disable master card, but i'm not sure where i need to put this script.
    Maybe someone know some tutorials about payment scripts??
    In short time we also need to change our payment system, and with new system we will try to make with latest version of zen-cart.
    We are using:
    Zen Cart 1.3.0.1
    Jun 2003
    Who is your merchant account provider?
    Jun 2006
    The Netherlands
    comfortpay / vxsbill.com
    Jun 2006
    The Netherlands
    I found this function
    $ccnValidation = "var nrcField = document.checkout_payment.number.value;\n" .
    "if ( nrcField.length < " . CC_NUMBER_MIN_LENGTH . ") {\n" .
    " error_message = error_message + 'Invalid credit card number.\\n';\n" .
    " error = 1;\n" .
    "}\n";
    this check only for lenght of min. number, can this check if is there master card first number :5 ?
    here is complete function:
    function javascript_validation()
    $ccvValidation = "var ccvField = document.checkout_payment.cvc.value;\n" .
    "if ( ccvField.length < " . CC_CVV_MIN_LENGTH . ") {\n" .
    " error_message = error_message + 'Invalid CCV entered.\\n';\n" .
    " error = 1;\n" .
    "}\n";
    $zipValidation = "var zipField = document.checkout_payment.zip.value;\n" .
    "if ( zipField.length < 4) {\n" .
    " error_message = error_message + 'Invalid ZIP code entered.\\n';\n" .
    " error = 1;\n" .
    "}\n";
    $addValidation = "var addField = document.checkout_payment.address.value;\n" .
    "if ( addField.length < 3) {\n" .
    " error_message = error_message + 'Invalid address entered.\\n';\n" .
    " error = 1;\n" .
    "}\n";
    $nameValidation = "var fnameField = document.checkout_payment.firstname.value;\n" .
    "var lnameField = document.checkout_payment.lastname.value;\n" .
    "var tName = fnameField + ' ' + lnameField;\n" .
    "if ( tName.length < " . CC_OWNER_MIN_LENGTH . " ) {\n" .
    " error_message = error_message + 'Input name length to low!\\n';\n" .
    " error = 1;\n" .
    "}\n";
    " error = 1;\n" .
    "}\n";
    $valChecks = $nameValidation . $addValidation . $zipValidation . $ccvValidation . $ccnValidation;
    return($valChecks);
    Jun 2006
    The Netherlands
    tnx to all, i found answer how to solve my problem,
    here is script if someone have the same problem...
    "if ( nrcField.substring(0,1) != \"5\");{\n" .
    " error_message = error_message + 'Sorry you use master card, please use one other credit card .\\n';\n" .
    " error = 1;\n" .
    "}\n";
    Jun 2003
    Thanks for posting the solution you found.
  1. Replies: 10
    Last Post: 10 Jan 2013, 08:13 PM
  2. Writing my own Payment Module?
    By Rayston in forum Addon Payment Modules
    Last Post: 29 Dec 2009, 07:42 PM
  3. Help needed with getting Paygate payment module to work
    By LeneZone in forum Addon Payment Modules
    Last Post: 4 Nov 2009, 11:43 AM
  4. MerchantAnywhere payment module - work with zen 1.3.7 ??
    By DogTags in forum Built-in Shipping and Payment Modules
    Last Post: 29 May 2007, 01:23 PM
  5. FAQ module doesn't work
    By dealbyethan.com in forum All Other Contributions/Addons
    Last Post: 14 Apr 2007, 03:03 AM
