Hi, My cart in progress is located here...
http://lifeonrecord.com/cart/index.php?main_page=login
The site I'm trying to match up the look to is located here...
http://www.lifeonrecord.com/prototype/signup.htm
The header on the cart is all set (except for the links behind the buttons, but I know how to fix those).
What I want to do is have the light blue background of the box in the second link be the background to the register feature of the cart. I believe it's just a one cell table with a blue background.
I also want to remove the grey bar in the cart that has the "Home" and "Log In" links. I thought that was the breadcrumb feature and tried to remove it from the Admin panel, but that wasn't it.
Finally, I need to adjust the width of the body of the content so it's narrower and fits inside the blue table.
Thanks in advance for the words of wisdom...
