open tpl_footer.php from includes/templates/YOUR_CUSTOM_TEMPLATE/common and find the following section:
<!--bof-navigation display -->
<div id="navSuppWrapper">
<div id="navSupp">
<ul>
<li><?php echo '<a href="' . HTTP_SERVER . DIR_WS_CATALOG . '">'; ?><?php echo HEADER_TITLE_CATALOG; ?></a></li>
<?php if (EZPAGES_STATUS_FOOTER == '1' or (EZPAGES_STATUS_FOOTER == '2' and (strstr(EXCLUDE_ADMIN_IP_FOR_MAINTENANCE, $_SERVER['REMOTE_ADDR'])))) { ?>
<li><?php require($template->get_template_dir('tpl_ezpages_bar_footer.php',DIR_WS_TEMPLATE, $current_page_base,'templates'). '/tpl_ezpages_bar_footer.php'); ?></li>
<?php } ?>
</ul>
<!--eof-navigation display -->
Do you have the line in red? If you do is it correct? if you don't have this line and want to add the home link back than place this line in.
