Results 1 to 3 of 3
    Default Please help with MSIE problem
    Hi all,
    I finished my site and much to late realized that MSIE behaves different then Firefox. (which I stupidly used setting up the site).
    When looking at www.musicmusketeers.com, using firefox and choose the link on the left called "dance music" you can see that the images line up the way they should aside eachother. So do the images when you click "Jazz and Fusion".
    Now when you open the same links in MSIE, the images under dance music line up underneath eachother, while the images under "jazz and Fusion" (all same size) line up the right way!
    I really hate those tricks, MSIE plays but I need it to be solved, so I really hope anyone could help me with this.
    Thanks a lot in advance for any usefull tips.
    Regards,
    Lex.
    Nov 2006
    Santa Fe, New Mexico, USA
    Default Re: Please help with MSIE problem
    You might try looking at this report:
    http://validator.w3.org/check?verbos...keteers.com%2F
    It reports 44 errors on your page, compared to XHTML 1.0, which is what the document references.
    It's possible that, if you correct these errors, IE and Firefox will give you the
    same behavior.
    good luck
    Hmmmm nifty tool you found there
    I can try that, thanks a lot!
    Lex
  1. Problem with IE PLEASE HELP!
    By semsenkir in forum Templates, Stylesheets, Page Layout
    Last Post: 3 Sep 2011, 12:48 AM
  2. MSIE Main Page Featured Products Problem
    By toothpickdog in forum Templates, Stylesheets, Page Layout
    Last Post: 10 Jan 2011, 12:33 PM
  3. Problem with IE 7 PLEASE HELP!
    Last Post: 30 Nov 2010, 02:20 PM
  4. CSS Problem when viewed with MSIE
    By Kaliboi82 in forum Templates, Stylesheets, Page Layout
    Last Post: 21 Dec 2009, 08:53 PM
  5. Please help, problem with function
    By ALISON MILLS in forum General Questions
    Last Post: 17 Dec 2009, 12:48 PM
