Results 1 to 7 of 7
    Nov 2006
    London, UK
    Default Multiple shop fronts with same products...
    I was just wondering... is it possible to have several shop fronts, with the same products, but a different shop front design? The idea is to have several shops running off the same database.
    I tried very quickly, but it seems that any change to, for example, the side columns in one store will reverberate throughout all the stores, and i want to customize the look of each, so it kind of defies the point.
    Is it possible to isolate the products, and list the same ones on several stores, but change the presentation of each store?
    Mar 2007
    Default Re: Multiple shop fronts with same products...
    This is exactly the same thing that I want to do.
    Did you get anywhere?
    I have tried OScommerce, but the multishop contribution just gives me grief.
    Cheers,
    DAVE
    Apr 2004
    UK
    It is possible..
    Design different templates:
    i.e Store1, Store2, Store 3 etc
    but when you upload them to each store's zencart templates
    folder, they should be named the same
    i.e. custom1,custom1,custom1
    so database thinks it has same template for all stores...
    Nov 2006
    London, UK
    Thanks... i don't get what you just said. You mean, under the same shop, I should make multiple templates?
    I don't see how that would work. So far I just managed to wipe out my entire database lol.
    Apr 2004
    UK
    NO!!
    Shop1...design template..name:custom1
    Shop2...design template..name:custom2
    Shop3...design template..name:custom3
    then, ready for upload via ftp
    Shop1..rename template, custom1, to mytemplate1..upload to Shop1
    Shop2..rename template, custom2, to mytemplate1..upload to Shop2
    Shop3..rename template, custom3, to mytemplate1..upload to Shop3
    Jun 2005
    Cumbria, UK
    If you can keep them on the same server, it's more secure, but remember... you are using ONE database, so the dbase setting are GLOBAL... What features in shop A (and how it draws data), will feature in exactly the same way in shops b, c, d and e.
    You'll be able to change a few cosmetics, but that's about it. If this is what you want to do, then it's possible - but not necessarily advisable. How will you know which shop is selling what?
    20 years a Zencart User
    Mar 2007
    You guys should check out Gerome's Multisite module.
    I have just started using it with a proof of concept working nicely so far.
    You can see my results here:
    http://dcinet.com.au/catalog/
    http://shop1.dcinet.com.au/catalog/
    http://shop2.dcinet.com.au/catalog/
    These are three discreet shops, each with a different look, all running from the one database so one product list with different products being offered at each site.
    You can read Gerome's thread here: http://www.zen-cart.com/forum/showthread.php?t=62908
    Dave.
  1. Changing multiple products at one? EG set and change same price for multiple products
    By jamesdavid in forum Setting Up Categories, Products, Attributes
    Last Post: 27 Aug 2008, 10:59 PM
  2. multiple products in the same category with the same weight.
    By highlander in forum Setting Up Categories, Products, Attributes
    Last Post: 30 May 2007, 06:46 PM
  3. Creating Multiple Page Fronts With One Checkout
    By enchantedlingerie in forum Templates, Stylesheets, Page Layout
    Last Post: 28 Mar 2007, 01:11 AM
  4. Using the same shop on multiple domains
    By michaelhl in forum General Questions
    Last Post: 15 Mar 2007, 06:46 PM
  5. Multiple Products-Same Attributes-Same Category
    By tolefairy in forum Setting Up Categories, Products, Attributes
    Last Post: 4 Mar 2007, 05:37 PM
