Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
  1. #21
    Apr 2005
    Default Re: Double click problem
    I have added a .swf preview for anyone who wants to see how it works. The attached file includes the script too.
    Attached Files Attached Files
  2. #22
    Aug 2006
    North Carolina
    oh well,
    no luck on my end with my test site.
    I use a custom template and I have some other checkout button. I have to figure out how to get around so that your code works with them. I just can't work on it tonight.
    When I tried it, nothing happened at all and acted as before.
    Also, I have a question on installation item #2.
    Should the extra code that is to be inserted replace what is after this code, or be inserted? There's a couple more lines at the end of the file and it seems as if I should put the new code over the top of it.
    Can you clarify?
    <<FIND THIS (near the line 36):
    function button_timeout() {
    document.checkout_confirmation.submit.disabled = false;>>
    Jeff Michaels,
    pres of Musical Creations Ltd.
  3. #23
    Apr 2005
    This attached file should have all the files already modified just copy them to there appropriate directories. I am really new to this too sorry for not including them.
  4. #24
    Oct 2005
    Hi Saltio,
    I've been having a major problem with double-clicking the confirm order button for a while, increasing to 4 or 5 a day in the last week. I'm trying to implement your java fix, but something's not right. Nothing changes after clicking the button. I'm guessing it's with the jscript_main.php file. Here's what I have at the bottom of that file after pasting in your code:
    function SubmitOrderButton(){
            document.getElementById("submitmain").style.display = "none";
    	if (navigator.appName == "Microsoft Internet Explorer") {
    	document.getElementById("pleasewait").innerHTML = "";
    	document.getElementById("pleasewait").style.display = "block";
    	document.getElementById("pleasewait").innerHTML = "<img src='images/pleasewait.gif' alt='Please Wait'>";
    </script>
    //--></script>
    Does that look right? Thanks for any help you can give.
  5. #25
    Oct 2005
    Ignore the previous post. I just found the zip file you attached with the files already edited. It's working great. Thank you so much!
  6. #26
    Default
    Saltio, thanks man, I was having this issue with my Zen 1.3.8 and it solved it! Odd this isn't included as "standard" in Zen, I was under the impression it was until I got 5 of the same order the other day because the shopper was super-excited and kept clicking the submit button, yikes!
  7. #27
    Jul 2004
    Another satisfied customer now just to stop the b@$%***$ who have switched off Javascript!
  8. #28
    Aug 2006
    North Carolina
    read back to post #19
    It fixed my problem last spring and the double clicking problem has never occurred again.
    It's great.
    I found out the original source of the problem was the use of a 3rd party template. This extra code in post #19 fixed that template.
    Jeff Michaels,
  9. #29
    May 2008
    orlando, florida
    Just another note to say thank you for this contribution! It works perfectly and will save us a lot of time and money in charge backs for duplicate orders. Great job and thank you!
  10. #30
    May 2008
    United States
    I was also having this issue, this worked great!
    Thanks to all that created it!
  1. Double orders problem
    By Batman1969 in forum General Questions
    Last Post: 23 Feb 2011, 10:05 PM
  2. Admin Order page double click
    By gaurav10feb in forum General Questions
    Last Post: 14 Jan 2011, 06:41 AM
  3. Double menu problem
    By NYsista872 in forum Templates, Stylesheets, Page Layout
    Last Post: 8 Aug 2010, 02:06 PM
