Assuming $currency is correct (vs $my_currency which you mentioned earlier), these should be fine:
zen_draw_hidden_field('currency', $currency) .
zen_draw_hidden_field('inputamount', round($order->info['total'],2)).
That simply submits the $currency value (which one would assume has been set a few lines earlier to be the value of either the currency code associated with $_SESSION['currency'] or the $order->info['currency'] .. whether GBP or USD etc, and submits the order amount which is based on the value of the order in the currency in which the customer placed the order.
You might try changing $currency to $order->info['currency'] instead ?
