You also need to specify the start position so it doesn't hug the left edge. background-position: top right;
And if I recall correctly the default is to tile the background, so you need to specify background-repeat: none;
#logoWrapper{
background-image: url(../images/header_bg.jpg);
background-color: #ffffff;
height:75px;
There are a lot of places you can add another background-image. Where it should go depends on *exactly* where you want it to show up.
