It's possible to have related products end we select 1 produt?
example: for this product we advise these products…
Zen Cart 1.3.7
Tanks
Zen Cart 1.3.7
Tanks
I used Cross-Sell Advanced,
It worked great for my purposes.
Hope it helps,
Steve
Stuff: ZC v1.37 | Linux | mysql v 4.1x | php v 4.4x | phpmyadmin v 2.6x | Default Template
Mods: Login Box v 1.41
There are two mods in Downloads > Marketing (link at top of this page): Cross Sell and Better Together.
Check them out and decide which one suits your needs.
But I install Cross-Sell Advanced, and dont work in zen 1.3.7.
"Sorry, your security clearance does not allow you to access this resource.
Please contact your site administrator if you believe this to be incorrect.
Sorry for any inconvenience."
this is the mensagem wend i press "Related Products".
them i change permision and this is the mensage:
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, [email protected] and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
can you help
I'm using it in 1.3.7 so that's not the problem. I'm not sure where the problen is but I'd read through the thread, or maybe retrace your instalation steps.
Maybe I can take a better look at it tonight. I have to go to my day job now.
Good Luck
Steve
