Hi there,
I have set up a zen cart for someone and everything was working well. Then she amended a product and since then I have this strange problem.
If I go into any product and add something to the description, everything is fine unless I try to put in some html. Even adding '<br>' will give the result that when I press the 'Preview' button, I get redirected to the main website. ie it leaves the zen admin bit.
For example
going from
www.domain.com/cart/admin/balhblah which if we imagine is a new or edited product with some html, after pressing preview, i end up at www.domiain.com - not even in the cart.
very strange, any ideas?
UPDATE: Okay, i've just tried to add some html to a review via admin, and the same thing has happened.....could it be a busted installation even though it was working?
