Results 1 to 7 of 7
    Default FedEx Module not returning rates -- hangs up shopping cart
    I installed the FedEx modle this morning, and all seemed well until I configured it and turned it on.. The Shipping Estimator and and Checkout hang. Did I set this up wrong?? Here's my configuration settings (I concealed some of the personal data with X's):
    Enable Fedex Shipping: True
    Your Fedex Account Number: 346XXXXXX
    Your Fedex Meter ID: NONE
    cURL Path: NONE
    cURL Proxy: NONE
    Debug Mode: True
    Weight Units: LBS
    Which server to use: test
    First line of street address: XXX E 1st St #226
    Second line of street address: NONE
    City name: XXXX XXXXX
    State or Province name: XX
    Postal code: 90802
    Phone number: XXX-505-6995
    Drop off type: 5
    Fedex surcharge?: 0
    Show List Rates?: False
    Insurance?: NONE
    Residential surcharge?: 0
    Enable Envelope Rates?: False
    Sort rates: High to Low
    Timeout in Seconds: NONE
    Tax Class: --none--
    Shipping Zone: --none--
    Sort Order: 4
    Default Re: FedEx Module not returning rates -- hangs up shopping cart
    Correction on configuration settings
    cURL Path: NONE
    cURL Proxy: NONE
    Debug Mode: False
    Weight Units: LBS
    Which server to use: production
    Postal code: 90802
    Drop off type: 5
    Fedex surcharge?: 0
    Insurance?: NONE
    Tax Class: --none--
    Sort Order: 4
    Mar 2004
    well if its hanging that means either the server you are on dosnt have cURL installed or its installed by proxy eitherway you need to contact your host to find out.
    You were absolutely right.. I added the cURL proxy data and WHOOSH, everything is working BEAUTIFULLY now!!! Sorry to trouble you sir.. and thanks again..
    Mar 2004
    not a problem thats what we are here for,
    Mar 2006
    Can you explain cURL? I see where to enable it but not sure what to enter for address information.
    Mar 2004
    you need to get the cURL information from your host.
  1. v139h USPS Shipping Module Not Returning Rates
    By WiccanWitch420 in forum General Questions
    Last Post: 10 Feb 2014, 05:23 AM
  2. Replies: 3
    Last Post: 14 Dec 2013, 02:40 AM
  3. v151 FedEx web services returning wrong rates
    By pexter in forum Addon Shipping Modules
    Last Post: 18 Jun 2013, 07:30 PM
  4. v150 Canada Post Module Not Returning Rates for me
    By DJLQD in forum Addon Shipping Modules
    Last Post: 15 Jun 2012, 06:03 AM
  5. FedEx Module will not show non-home rates.
    By gcntim in forum Addon Shipping Modules
    Last Post: 16 Jan 2010, 12:09 AM
