    Mar 2006
    Melbourne, Australia
    Default serious permission problems
    My 1.3.7 install has worked with no issues until today, when I could not edit a product description without getting a permission denied error. Similarly, when I try to upload an SQL patch, I am denied permission:
    'You don't have permission to access /xxxx/admin/sqlpatch.php on this server.
    Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request. '
    I have changed permissions on sqlpatch.php, cleared cookies, emptied cache and temporarily removed .htaccess, all to no avail. Any suggestions?
    Default Re: serious permission problems
    1. What did your host change? (you said it just suddenly started, right?)
    2. What are your file and folder permissions in your /admin folder?
    Mar 2006
    Admin folder is 755. I set sqlpatch.php to 777 as an experiment, but no go. I note also from the forum that there may be a problem with the extra_pages module, as the is a second version which refers to a fix re: the sql file.
    But that would not explain the continuing problem with entering product information. I'll ask if there have been any changes. Thanks.
    Mar 2006
    Solution: since my host made changes, I now must have
    SecFilterEngine off
    in my .htaccess file.
  1. Serious Problems need help asap please
    By doll5272 in forum Basic Configuration
    Last Post: 1 Jan 2009, 08:16 PM
  2. Backing up database gave me serious problems
    By Pauls in forum General Questions
    Last Post: 15 May 2007, 11:38 PM
  3. Serious problems with my orders....Urgent help!!
    By lina0962 in forum General Questions
    Last Post: 4 May 2007, 04:21 AM
